For marking out, thank you – I have both a surface plate, angle plate, scriber and height gauge so I think I'm covered in that regard.
Also tThank you for the advice on the over-large standard bore. It makes perfect sense. Re-clocking the standard it looks like it is parallel and central, but about 0.668" instead of 0.625". Unfortunately the cast crosshead is about that across the widest point in unmachineed form.
I have some 3/4" brass rod handy, so my thoughts are to open this out to 11/16" / 0.6875", machining the base of the cylinder cover to fit. I will need to fabricate a new crosshead but I don't think that should be too hard with my vertical slide?
The reason it was bored over size is that I was impatient to get started so was using some jury rigged clamping which shifted during boring, ending up with hole eccentric to the (now turned) outer rim – I thought I had miles of room so re-clocked and bored concentric – and then found myself in this spot.
Re: Harold Hall's site – I've read the build and seen some of the clamping and fixtures which look promising, I have ordered some plain aluminium to fabricate some of those pieces, too.
Edited By William Ayerst on 28/05/2021 14:14:31
Edited By William Ayerst on 28/05/2021 14:33:52
