how to make it stay in ?
Home Forums Beginners questions how to make it stay in ?
  • #592010
    J Hancock
      @jhancock95746
      A 'loop ' pin in each plug with a 'rubber band' through the hollow axle .
        Posted by David Senior on 29/03/2022 22:08:55:
        Turn a groove on the section that fits down the tube, and fit an O-ring. Use a fairly chunky O-ring and play with the groove diameter to get a good grip. …
        I like this one – easy to make and fit, won't damage the bike, and unlikely to get stuck or corroded in place! I'd worry about finding an O-ring just the right size, but I've no idea what's available.
        Nick Wheeler
          @nickwheeler
          Posted by SillyOldDuffer on 30/03/2022 09:28:38:
          O-ring sets are cheap, and well worth having if you do this sort of thing.
          Or you could glue a custom size one together, as this isn't a critical sealing job
          #592040
          Hopper
            @hopper
            Google Harley Axle Plug and see how the pro's do it. Good healthy spigot sticking 3/4" inch or so into the hollow axle, with an o-ring to hold it in place. If they rattle a bit loose, a dob of silicone sealer holds them in place but allows dead easy removal. **LINK**
            #592080
              Posted by Nicholas Wheeler 1 on 30/03/2022 09:54:14:
              … I'd worry about finding an O-ring just the right size, but I've no idea what's available.
              … you could glue a custom size one together, as this isn't a critical sealing job
              Doh, now I feel daft – that's so obvious!
              blush
