How to find ALL your old posts
Home Forums New Forum Software questions, comments and Test Threads How to find ALL your old posts
  • #680049
      Well almost
      I have seen several questions and suggested answers on how to find/where are my old posts. I have just found how to list all the old posts you were active in.
      Go to your profile
      Click Forums
      Click Engagements
      They come up in date/time order and go back for many pages, 420 in my case which is almost 10500 threads
        Impressive sleuthing, Jason
        There it was … ”hidden in plain sight”
        peak4
          @peak4
          That’s interesting; I tried it last night and got no results, but it works OK for me now.
          The two boxes to the left of it did, and still do work OK as I added screenshots in a different thread, probably whilst you were typing this. (Topics Started & Replies Created)
          Helpfully it even works if you click on a different user’s profile, so I can look at Michael’s engagements etc.
          The difficulty is that I first need to find a post by Michael, so I can click on his user profile.
          Bill
          #680199
          Anonymous
            Kind of buried and not exactly intuitive but that probably doesn’t matter once you find out.
            This will help Gray!
            #680241
            Thor 🇳🇴
              @thor
              Thanks Jason
              #680385
              vic newey
                @vicnewey60017
                Well, that’s a brilliant discovery as all the photo’s on threads I posted are still there as well !
                I also notice that any of those old threads can be instantly resurrected by simply adding a reply
                #680386
                  One slight problem with that but I won’t make it public and it won’t affect usual posting or carrying on with old long-running threads such as build logs. Now Michael will be digging deep to see what it is.
                  #680430
                  vic newey
                    @vicnewey60017
                    I just replied to one of my old posts re a vintage hand vice and it’s appeared o.k
                    #680475
                      Please Sir … I think I’ve sussed it !
                      https://www.model-engineer.co.uk/forums/topic/a-vintage-hand-vise/#post-680471
                      KEITH BEAUMONT
                        @keithbeaumont45476
                        I do not have “engagements” on my page, just Profile and Forums.
                        Keith
                        #681533
                        Nicholas Farr
                          @nicholasfarr14254
                          Hi Keith, you need to click on forums after you’ve clicked on your profile.
                          Regards Nick.
                          #681628
                            Keith
                            Profile on the green bar
                            Then Forums on th escreen that comes up (NOT the one on the green bar)
                            Then Engagements when the screen changes
                            #681680
                            KEITH BEAUMONT
                              @keithbeaumont45476
                              Thanks Nick and Jason. I have found my Engagements.  I suppose we will get used to the new system eventually. The work the Mods have had to do in the past weeks is staggering. I hope they all think it worth it ,finally.
                              Keith
                              #681708
                                Keith
                                Not just the mods!  We’re bombarding Mortons with bugs and requests where a single developer does most of the work.  I’d buy Andy a well-deserved pint if I met him.
                                Nothing spectacular, but I’ve noticing a number of things have started to work properly over the last two days.  (Gallery still wonky, but I successfully published a PDF from it, and it was broken before.)  Good to see progress.
                                Don’t know how fixes are being prioritised.  Educated guess, I suspect the ‘latest posts’ performance problem is difficult and WordPress and the hosting service have been asked for advice.  Whilst waiting for them, makes sense to tackle some quick fixes, even if the benefits aren’t instantly obvious to us.  Always helps to remove some grit from the works when you have the chance.
                                KEITH BEAUMONT
                                  @keithbeaumont45476
                                  When things have reached a state of general satisfaction, There is an opportunity for one of you to write a book- Instruction on How to use the Forum !
                                  Keith
                                  #681854
                                  Graham Meek
                                    @grahammeek88282
                                    Three Cheers for Jason,
                                    Thanks Jason I can at least jog my memory now.
                                    I think you are in the running for the Chairman of the self help group, and from now on, the man to go to.
                                    Gray,
                                    #683956
                                    Nicholas Farr
                                      @nicholasfarr14254
                                      Hi, one little niggle about the Engagements is, while you can select one of the first or last three pages, you can only get to the middle ones, one at a time after the last number or third from last number visible, so it takes an awful long time to select one in the middle, why the two arrows at each end won’t advance the page numbers, so you can then select a page number of your choice, I don’t know. Having said that, it seems that all the “What did you do today?” topics before the current one, cannot be found, and it was a post I believe I made in the 2022 one that I was looking for.
                                      Regards Nick.
                                      #684122
                                      alan ord 2
                                        @alanord2
                                        Jason, how do I find my albums in this new format?
                                        Alan.
                                        #684160
                                        Anonymous
                                          Alan.
                                          They are GONE.
                                          Answered numerous times if you dig around and was advised on the old site before it closed.
