How to drill a square hole?
Home Forums Beginners questions How to drill a square hole?
Viewing 25 posts - 1 through 25 (of 29 total)
  • #53688
    Alexander Edblad
      @alexanderedblad56890
      Seriously  now.
      The buffer beams for my Invicta should have 1/8″ cutouts for the coupling hook. What is the easiest way to do this? I guess I could drill four or so small holes and then file to get it square. Are there other options?
      Thanks
      Alex
      Alexander Edblad
        #53689
        Peter G. Shaw
          @peterg-shaw75338
          I do remember reading about this on a number of occasions. Yes it is apparently possible – see MEW 14 etc and MEW112.
          As I understand it, the idea is to have (for a square hole) a triangular cutter which is allowed to move around whilst being rotated. Sorry, I know that doesn’t make sense, but it’s the best I can do at the moment. What happens is that the cutter starts to dig in at the corners, rotates, and the next cutter point swivels round to produce the next corner. and so on.
          But what about using a broach. Here you would have a piece of tapered hardened steel (silver steel) with transverse cutting edges on all four sides. Pressing the device into a circular hole then cuts the corners. For a better description try Len Mason’s book Using the Small Lathe. I suppose it’s like reaming, but in an axial dimension rather radial.
          Good luck,
          Peter G. Shaw
          #53690
          NJH
            @njh
            Hi Alexander
            I guess for 1/8″ drill and file is the best option……however it IS possible to drill square holes!
            You need the Henry Watt  square drill bit!
            Other than the animation on this page I’ve never  seen it in action however my current project is Anthony Mounts Trapezium Connecting Rod Engine – a design attributed to Professor Reuleaux.
            No — in your case get out the files!
            Good luck
            Norman
            Edited By NJH on 21/07/2010 13:34:55
            #53697
            Richard Parsons
              @richardparsons61721
              There are four ways of doing this. Three of these have been written up in the Model Engineer/ Model Engineer’s Workshop.  For your 1/8” square holes in the buffer the best method to make up a punch broach. You make a tool which slowly graduates from a 1/8” round to a 1/8” square over length (in this size) of about 25mm. You then machine a series of cutting faces about 1 to 1.5 mm apart on it from the round end to the square end. Harden it and tonk it through the 1/8” hole you have drilled. This was written up in the mid 90s in Model Engineer.
              The next method is to make and use a Rotating Broach.  This was written up recently in (I think) MEWS but I just cannot drop my hand on it. Hungarians cannot leave anything alone so God knows where it is. There was this morning also a picture of the tool somewhere on this website. It will graunch out almost any shape you can make the tool for, but it takes a rigid and powerful lathe to drive it at any speed.
              Third way, which was written up in MEWS about 3 years is to use a drill based on a Reuleaux curve. This uses a Warrington coupling but will not drill a pure square, the corners are rounded. I made two 1 for me and 1 for a company, which had a problem. They had a problem with a 12mm square hole in a casting about 25mm deep. It should have been cast in but it weren’t. just after they had shipped the first dozen or so Suzuki decided to send the castings back (the model was not selling).
              In the whole as you only have 4 to make I would drill the hole and file it square – a lot less fuss.
              P.S. this shows I did not read Mr Shaws posting above!
              Edited By Richard Parsons on 21/07/2010 16:57:15
              #53716
              Steve Garnett
                @stevegarnett62550
                I only make that three ways!
                Small EDM? That looks like a neat way of making just about any shaped hole you can think of…
                #53718
                Rob Manley
                  @robmanley79788
                  1/8″ square is easy enough to file with a small needle file.  I wouldn’t even consider any other method.  But as has been said another method is to half grind a bit of 1/8 tool steel into a D shaped broach and take out the corners of an 1/8 hole by planing.
                  One day I will get around to playing with this:
                  #53725
                  Sam Stones
                    @samstones42903
                    Hi Alex,
                    I’ve always been intrigued about drilling square holes when, as an apprentice, one of the toolmakers told me it was possible using a triangular drill which went around in an orbit. That was the limit of his explanation.
                    Norman (NJH) has hit upon a good web-site htttp://mathworld.wolfram.com/ReuleauxTriangle.html which is sufficiently animated to understand the principle.
                    Isn’t it a version of our old friend, the epitrochoidal? Better known from its use in the Wankel (NSU and Mazda) rotary engines. There’s a book (somewhere) which describes a multiplicity of rotary engines. It features a range of epitrochoidal orbits from two lobe onwards.
                    Rob Manley’s directive to the `square hole drilling’ video, is well worth watching, but I haven’t worked out how the drill can be fully inserted in the round hole immediately. But re-running and closer inspection of the video shows that the workpiece already has a square hole in it, and the drill chuck is designed to slide freely in any direction at right angles to the drill axis. The drill also appears to be driven by the workpiece. I have to presume that the size limit for the square hole is a direct function of the triangular drill dimensions. Could it be that to get things started, there has to be a slightly recessed pilot hole equivalent to the diagonal of the square minus the corner fillets?
                    While it would be a nice exercise to build the drill mechanism, with only four small holes to square and corner out, I’d stick with filing too Alex. Some of the needle files might even be 1/8″ square anyway, so there’s the makings of your broach.
                    Sam
                    Edited By Sam Stones on 22/07/2010 02:37:52
                    #53742
                    Ian S C
                      @iansc
                      Starting the drill needs the square guide that fits over the hole area, this is what governs the size of the hole. Ian S C
                      #54110
                      Ian Abbott
                        @ianabbott31222
                        At Torbay Steam Fair today, I met a man from Brixham Model Club, who had a square drill on display.
                        I can’t remember the correct name for the rounded triangular bit, but essentially, it is a three face end mill, guided by a square hole, which mills out a circular hole to square.
                        I’m still getting the photos organised, but I’ll post a picture or two when I’ve done in a day or two.
                        Ian
                        #54125
                        Sub Mandrel
                          @submandrel
                          How do you drill the square hole in the guide?
                          Ian Abbott
                            @ianabbott31222
                            Ah, you drill it on a milling machine.
                            (Two pieces of “L” shaped steel bolted together)
                            Ian
                            #54140
                            Ian Abbott
                              @ianabbott31222
                              The image doesn’t seem to want to load on here, but if you look on the “Latest Photos” bit, it’s there.
                              The gentleman’s  name is Nigel Whiteway (I hope I got that right), it was noisy.
                              Ian
                              #54141
                              Ian Abbott
                                @ianabbott31222
                                I looked it up, the shape of the drill bit is called a Reuleaux Triangle, which has a constant width and can roll like a wheel.  Which Nigel also had on his table.
                                What did we do PW.  (Pre Wikipedia)
                                Ian
                                #54153
                                jacques maurel
                                  @jacquesmaurel42310
                                  Look at my articles in model engineer: N°4285 page 493 for square hole drilling, I’ve also made un attachment for hexagon hole drilling, the process is slightly different, you can get sharp edges, the drill is not a solid of equal width. Ask the editor to contact me if you want a short artilcle about this  subject in the magazine. The main interest of the article (about square hole drilling) is the description of a floating tool holder very usefull for reamer holding. The second article is in ME N° 4310 p 432 about polygonal punching tools, this way is I think more convinient for small dimensions. I’ve put many videos on youtube, just tap “square hole drilling or hexagon hole drilling. Visit my website: jacques maurel.com
                                  #54161
                                  Jim Whetren
                                    @jimwhetren72358
                                    Hello Alex,
                                    I have been following the thread with interest and was surprised that the Rotary Broach didn’t get a mention.
                                    A version of this tool was described by Jock Miller in MEW issue No. 157. It is quite straightforward to make, and the tool bit is easily ground on the most basic of grinding set ups.
                                    Also the chicken & egg problem with making a square hole in the guide bush to produce a tool to make square holes is eliminated.
                                    In the case of the buffer beam, you would just drill a pilot hole the AF size of the square, countersink it to just accommodate the cross corners size of the bit, then position the square in the correct orientation and ‘drill’ away.
                                    Good luck with it,
                                    Jim
                                    #54165
                                    WALLACE
                                      @wallace
                                      Don’t know about a square hole but I find it all too easy to put a triangular one into thin metal  when I want it to be round . .
                                      w.
                                      #54219
                                      jacques maurel
                                        @jacquesmaurel42310
                                        Corrected post
                                        Edited By David Clark 1 on 17/08/2010 15:19:50
                                        #54383
                                        jacques maurel
                                          @jacquesmaurel42310
                                          Please use the little button above with the Word logo on it.
                                          Third from right.
                                          This should convert from Word to text when you paste it.
                                          regards david
                                          Edited By David Clark 1 on 17/08/2010 17:10:33
                                          #54407
                                          jacques maurel
                                            @jacquesmaurel42310
                                            For polygon drilling, there isn’t any problem of “chicken and egg” as the guide can be made in 2 parts assembled together. Nevertheless this process needs tooling (floating toolholder, guide, drill) and it’s difficult to get an accurate dimension for the hole.I’ve made it to amaze my students, and to have a good floating toolholder for my reamers. The rotary broaching process is not easy too (rotating toolholder) the adjustment of the toolbit is described in a video on “youtube” it’s not an easy task for a one off job. While you have made the tool bit, it’s easier to strike it ( see ME N°4310).
                                            #54734
                                            Anthony Knights
                                              @anthonyknights16741
                                              The cutter in Mr Abbott’s picture appears to have a constant diameter cross section, made from 3  x 120 degree arcs centered on the opposite vertex. I seem to remember pencils with a similar cross section. Machining one in a 4 jaw chuck shouldn’t be too difficult, assuming one takes care with the setting up.
                                              Hi there Wallace. The triangular holes thing is another manifestation of the constant diameter phenomena mentioned above. I find the best way to drill holes in thin metal ( without making a special drilling jig) is to clamp it between two pieces of wood. I have recently replaced the flooring in the lounge and now have enough MDF laminate to use for this purpose until I am called to the great workshop in the sky.
                                              Warrington coupling was mentioned in one of the posts, but putting this in Google did not supply any useful information. An Oldham coupling was also seen on my trawl for more information. Could this be a Lancastrian thing ? A Manchester screw driver (AKA Big Hammer) springs to mind.
                                              Tried “Floating tool holder” and was directed to the U.S. patents site, where the are s**t loads of entries for this. Drawings are available for download. One of these  has been added to my future projects list, as has the recently published “Wobble Broach” tool.
                                              #54763
                                              Ian Abbott
                                                @ianabbott31222
                                                Apparently, the constant diameter triangle used on the cutter in the photograph is achieved by mounting three pieces of hexagonal bar in the three jaw chuck, then rotating the bars by two flats each to bring the next face into line.
                                                This procedure gives one three triangular lengths of bar after three rotations.
                                                This is how it was explained to me by the maker.
                                                Interesting thought here, with a constant diameter triangle, it shouldn’t matter how you position the bar in a three jaw chuck to machine a diameter on the end.
                                                Ian
                                                #54809
                                                Anthony Knights
                                                  Just a thought. If the item has a constant diameter, why would you need to turn a cicular end on it?
                                                  #54810
                                                  Anthony Knights
                                                    Sorry. I have a dyslexix keyboard. I meant to type ciRcular.
                                                    #54813
                                                    Ian Abbott
                                                      @ianabbott31222
                                                      It’s not so easy to fasten a triangle into a bearing or onto a driving shaft.
                                                      However, on that subject, the geometric centre of the triangle isn’t in the middle, if that makes sense.  Or, while the upper part of the outer surface will maintain a constant distance from the surface that it is rolling on, the centre of the triangle goes up and down relative to the surface.
                                                      That’s as much as my mind can manage after a day in the noise of the Dartmouth Royal Regatta, which ended the day with a free air show, featuring the Red Arrows and the Tornado on reheat.
                                                      Ian
                                                      Who’s hearing wasn’t deficient.
