How to draw a set of holes on a PCD using Autocad 2000
Home Forums CAD – Technical drawing & design How to draw a set of holes on a PCD using Autocad 2000
  • #608830
    Greensands
      @greensands
      Hi – I am having problems in drawing up a set of holes on a PCD using Autocad 2000. Having successfully DIVided the circle into the required number of divisions I was expecting to be able to ‘snap’ onto the division points to draw the required circle of holes but have discovered that OSNAP settings options does not seem to recognise the DDPTYPE markers inserted using the DIV command. Can someone please explain where I might be going wrong.
      Greensands
        @greensands
        #608838
        Nick Wheeler
          @nickwheeler
          Does Autocad have a radial pattern tool? That allows you to pattern a feature as many times as you need around a fixed point or axis?
          Edited By Nicholas Wheeler 1 on 09/08/2022 10:51:38
          #608844
          Martin Connelly
            @martinconnelly55370
            You should use polar array. Draw one circle on the PCD circle. Select it then go to array. Chose polar array, choose the centre of the PCD as the centre of the array, choose how many circles are required and the angle to fill (usually 360° ) and that should do what you want.
            I think arrays are in the modification menu.
            Martin C
            Smiley!!!
            Edited By Martin Connelly on 09/08/2022 11:11:22
            #608849
            DC31k
              @dc31k
              Which OSNAP are you using? To snap to a point, you need NODE.
              Another way to do it is to use the polygon command. Choose the number of vertices as the number of holes. Choose INSCRIBED as the method for drawing, with the dia. of the inscribed circle the PCD required. Draw a circle at each vertex.
              Polar array as suggested above is quite powerful as you can choose any combination of number of items and angle to fill (so you could put 9 things around a 17 degree arc if you wanted).
              #608856
              Greensands
                @greensands
                Martin – Problem now resolved using the polar array command.
                DC31K – Yes, have also had success selecting the OSNAP NODE option
                Many thanks guys.It is a very helpful forum.
