I can honestly say that i never even considered linolium as a bench surface !
I can see its merits though – reasonably cheap , hard wearing and noise dampening . The only downside i see is i doesn't like heat and you will have to glue it down to stop it curling up but it could be glued to some thin ply or masonite which has been pinned to the bench top with a few small screws or some brads.
I have also considered formica sheet but it seems hard to find , i can't go to my local hardware store and buy it here in Sydney Australia and what there is on ebay seems expensive . I also have another issue and that is i tend to plonk heavy odd shaped items up on my bech to work on them i find that while working on them i have to slide , roll , tip them over and it damages the bench surface and i'm a little worried it will gouge or chip the formica .
I can pick up some lino tiles for a few bucks so i may glue some to a piece of thin ply and sit it up on the bench as a test piece to see how it goes , i could also do the same for the formica as the drill press bench has a slab of particle board covered with formica that is being replaced with a new bench so i can cut a piece off the top and try that .
I already have a steel top moblie bench i use for welding so i know what it can handle and what its pros and cons are : pros – Hard wearing heat resistent easy to repair.
Cons – Goes rusty if not oiled , noisy to work on ,scratches softer surfaces like alloy and sucks the heat out of a cup of tea real quick !
My main workbench is only 6ft x 3ft so there is the optoin of having an interchangeable slide on bench surface / cover that could be quickly changed over as needed .
Much to think about !
Ian .
Edited By XD 351 on 24/08/2017 22:27:02
