Simple answer is use a DXF file.
Talk directly to the people/company that are going to do the cutting (not an agent or go between).
Laser and Waterjet (dearer) can and do produce accurate predictable results but there are little details (nuances really) that if allowed for, can make the product (and your life!) a bit easier.
Depending on the material thickness, there may be a divot at the start and end of a cut that without preparing for, might end up just where you dont want it.
You also need to think about materials, if the laser cutting company are supplying and they normally make heavy engineering parts where the surface finish is going to be powder coated, your parts might end up unsuitable for cosmetic reasons.
If the material you are going to use has a directional finish (say its brushed SS) then the orientation needs to be indicated on the DXF.
Ian P
Edited By Ian Phillips on 04/09/2013 16:55:34
