Thanks for the reminder about the vast majority of heat transfer taking place in the firebox. Kozo states that “90% of steam is generated on the surface of the firebox or on the crown sheet” in ‘The Penn. A3 Switcher’ (but no source or evidence given). This does beg questions about the ideal size of firebox of course, perhaps the problem in model locomotives is that the prototype dimensions decide the (exterior) firebox size, which might be significantly smaller than the ‘ideal’, thus often requiring more tubes (and tube surface area) than the three relatively large diameter tubesthat Kozo now seems to prefer.
K Wilson, ME Vol.200, No.4327, page 700, 6th June 2008, writes: ……
“Length of firebox is settled from the prototype. But if such does not exist, then firebox length could be about half the length of the barrel for a narrow box (Belpaire), or the equivalent square or a wide or Wooten box.’
Continuing to refer to the arrangements for boilers constrained in firebox design by the prototype Wilson writes:
“Tube length should work out at 1.5 to 2 times firebox length. If longer than that a combustion chamber should be considered……….
He later continues to give a tube spacing of :
” 3/16 inch between neigbouring tubes in 7.25″, 1/8 inch in 5″, not less than 3/32 inch for smaller sizes’ (see I have got back to the thread title & tubes!)
I have just looked at the Kozo ‘switcher’ boiler in 3.5″ gauge… Firebox (4.25) is 1/3 of boiler length (12.75″), but combined with the three large tubes (0.78″ or 20mm outside diam.)
It is interesting that Kozo most recently uses fewer and larger ‘staybolts’ than ‘we’, (i.e. LBSC, Evans, Wilson, etc.,) would seem to use (six 3/16″(?) at 1″ centers each side of the firebox in the 3.5″ switcher), thus in combination with the fewer boiler tubes making the boiler easier to construct with less soldering etc. Perhaps this approach would increase the numbers of people constructing their own boilers – refer to topic on the subject on this forum – whilst not significantly affecting the steam generation ability???
I would be interested in exploring this whole topic of tube/firebox sizes etc., both ‘ideal’ and how to fit to prototype constraints in the light of the most recent thinking. Has anyone any sources of info’?
I realise that many (most?) model engineers might consider this to be a rather esoteric theoretical pursuit of little or no interest…….. However……. Maybe boiler simplification and updating is how some older designs could be ‘updated’ and made more easy to construct to satisfy requests for such updating.
