How long for Humbrol clear model varnish to cure and apply decals?
Home Forums The Tea Room How long for Humbrol clear model varnish to cure and apply decals?
  • #662829
    Simon Robinson 4
      @simonrobinson4
      I’ve painted my model with the 3 recommenced coats of Humbrol Clear, leaving over 30 minutes between each coat. It doesn’t say on the instructions but how long will it take for the varnish to cure so I can apply my waterslide decals?
      Edit: it’s an acrylic varnish.
      Edited By Simon Robinson 4 on 04/10/2023 13:00:34
      Simon Robinson 4
        @simonrobinson4
        #662830
          Is this acrylic or enamel?
          From experience, the enamel is slow drying and wants a lot longer tha 30 minutes between coats, or it could take several days to cure.
          Acrylic should dry a lot faster.
          Neil;
          #662832
          Simon Robinson 4
            @simonrobinson4
            Posted by Neil Wyatt on 04/10/2023 12:55:34:
            Neil;
            It’s an acrylic water based varnish.
            #662834
              This is what Humbrol say:
              Enamels: Gloss: 1-2 hours. Matt & Satin: 20-40 mins touch dry, up to 24 hours for hard dry. Metallics: hard dry in approx. 10 days. Recoat: 6 hours minimum.
              Acrylics: 1-2 hours ‘hard dry’, allow longer for Gloss and Metallic finishes.
              uk.humbrol.com/support-and-advice/advice/humbrol-product-guide
              #662835
                Posted by Simon Robinson 4 on 04/10/2023 12:59:48:
                Crossed in the post!
                It should dry fairly fast, I would normally leave acrylic a day before applying decals, just to be on the safe side.
