Posted by SillyOldDuffer on 19/06/2021 12:27:57
Back home, I wasted another couple of hours debugging a computer maths problem which turned out to be a bleeding obvious beginner mistake. (BODMAS!) It's because I flit between jobs, never mastering anything. I can do electrics, plumbing, woodwork, tiling, gardening, fix cars, and cut metal: none of them well!
Me too Dave, on all counts. Your 'bleeding obvious' BODMAS mistake is interesting. Back in the day I would have students come to me shamefaced because they'd spent hours (days even!) trying to debug their code, and couldn't figure out where they'd gone wrong. Blame the computer! Invariably it was a simple BODMAS type error, which I spotted quickly because I was reading the code with an unprejudiced eye – in trying to debug my own code my eye would just run uncritically over a similarly simple error, following the original track of my mind.
Back to machining – I decided to make the boss for the handwheel separately planning to to braze or glue it into a disc which would be the handwheel. My latest schoolboy error – I turned the boss, drilled and reamed 12mm to fit the machine spindle, then bored 19mm H7ish (that's a new ISO standard) to fit the gear:
![offeringgear.jpg offeringgear.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
I then realised that I had no easy way of enlarging the 10mm gear bore to make a smooth transition to the 12mm bore in the boss. The gear will be fixed in the boss by a grubscrew – I should have fixed them together before reaming. Doh! I think I can get away with it, but I'm annoyed with myself for not having thought it through properly.
To give context, the project is a replacement wheel to fit this arrangement:
![kityspindle2.jpg kityspindle2.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
The spring pushes the handwheel toward the operator, which allows a dog-point grub screw in the handwheel boss to engage with the spindle and actuate the blade rise/fall mechanism. Pushing the handwheel in disengages the dog and engages the plastic spur with the steel rack to give blade tilt. With, you'd think, perhaps,
![kitywheel2.jpg kitywheel2.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
an inevitable result.
2,5 hours and counting….
Robin.
Edited By Robin Graham on 24/06/2021 23:58:23
Edited By Robin Graham on 25/06/2021 00:07:10
Edited By Robin Graham on 25/06/2021 00:11:36
Edited By Robin Graham on 25/06/2021 00:17:16
