I bought a Soba about 15yrs ago from Chronos and it's fine and the one I usually reach for. Had the ARC one since I did the Milling for beginners Series and can't tell the difference, tend to keep this with the R8 arbor on it for occasional use on the SX2.7 though arbors are interchangable.
The carbide supplied really only needs a touch up with a diamond slip unless you want to start modifying the shapes for things like external work. I almost always use an insert bar in mine, Set of three Glanze ones via Chronos.
One other thing to bear in mind is that 2" heads tend to take 1/2" tooling and the 50mm ones 12mm or 1/2" depending on source so think ahead of what you might want to use with it.
I suspect the Axi one is actually 2" as it takes 1/2" tools and has imperial scale
Edited By JasonB on 31/08/2023 11:06:22
