A chap who goes by the Alias Toolgrinding has asked me via PM how I made my 55° gib strips for my X1 back when I owned one. I thought I'd pop the answer down in a thread so its open to all as I don't think I've seen it done like this- I'm using what I've got, which is just a 4mm endmill, and a standard T slot clamp kit + the appropriate size spanner, and piece of wood to protect the machine table – oh and a calculator or a good head for numbers, if you've got a spreadsheet program you can probably use that to work out the numbers.
This is just my way, I don't have any of this sort of industry experience, I'm just using my head, I'm sure there's room for improvement.
I recall many people were cutting a groove in a bit of wood, then glueing the strip in and machining it. I didn't have that option all I had was the mill itself, so I had to make do with that, the results were very very good.
I measured all 3 gibs, they were all the same thickness – the Z looked thinker – but it wasn't it was just a few mm shorter. so I bought some brass flats the appropriate size – slightly thicker than the ones fitted, as I was confident there was room – 1/8" if I recall, but I suspect this could easily change from one machine to the next or even one gib to the other.
I fastened the strip down to the table and aligned it to the X axis with the DTI (it was sat on a piece of old laminate floor board to protect the bed.)
I then took a small 4mm ball nose cutter and calculated the combined Z and Y movements required to machine the 55° angle through the strip and well in to the laminate (minimum 2mm to pass the ball nose) – I calculated about 6 steps.
Zero'd the Z and Y to the edge of the strip facing me, and started a surface pass far enough back to allow the cutter to drift forwards and down, forwards and down, and again and again, by the values I'd already worked out to create the 55° slope. (ie, I move Y, lower Z lock Y and Z, and then feed X the full length of the strip, and go to the next Z,Y positions)
I deburred & flipped the part and repeated – this time zeroing on the rear of the strip and again, back to the calc sheet to then work out how far forwards I need to start the cut in order to get the correct height strip (they were all slightly different on mine, and again, I made them slightly larger than the existing ones to be a better fit.
Once trimmed to length I did a quick test fit and blued the end of my already made ball ended adjusting screws to mark the 4 locations that I needed to spot face the strip – you should really take care here, if you drill to high or low, or have differences between the holes height or gap you could distort the strip – you might find it works to just not bother they will make their own mark in time at a guess.
I then planned on hand filing the steps out, but they were so close I just left it, I don't think the top and bottom edge are doing much anyway
The hardest part was measuring the geometry required, I seem to remember I had to remake the Z strip.
Care must be taken no to overtighten the strips, as you probably won't notice if you do. It will obviously wear much quicker than a steel strip but I found I didn't have to adjust mine in the all the time I had it (a year or 2?)
I hope that makes sense, fire away with the questions if you want –
Toolgrinding, I think I kept them when I sold the machine, if I can find the old strips in the garage (if they've not been recycled!) then I'll let you know, you can have them.
