How does this work.?
Home Forums Hints And Tips for model engineers How does this work.?
  • #220993
    Nick_G
      @nick_g
      What is the reason / physics behind this working.?
      Nick
      Nick_G
        @nick_g
        #220995
        nigel jones 5
          @nigeljones5
          no idea but im going to try it
          #220999
          ASF
            @asf
            would it be because 1 cutting edge is cutting before the other causing the shaped hole and putting a rag bit in there levels out the cutting edges to stop wander?
            #221001
            John Stevenson 1
              @johnstevenson1
              Dunno but I'll bet he discovered it when his shop coat got caught in the drill. wink
              #221003
              Ady1
                @ady1
                The cloth gathers the swarf and it doesn't get the chance to damage the hole?
                Does it work fine without cloth at higher speeds? (lighter swarf)
                Edited By Ady1 on 14/01/2016 01:10:03
                #221006
                Dinosaur Engineer
                  @dinosaurengineer
                  This "trick" is as old as the hills. I was taught this by an old toolmaker in the mid 50's ! The emery cloth puts a small chamfer on the edge of the hole before the drill starts cutting and it stops the drill from biting too quickly. Also the cloth supports the drill between the 2 cutting points and minimises the drill wandering from the proper circular path. 3 flute drills are much better at drilling thin material as the drill is supported by 3 points and not 2. The method shown does result in a hole slightly bigger than the drill because of the extra material taken out by the emery. Clamping some thicker scrap material on top of the thin material to be drilled will give the drill better support and minimise any "wandering" by the drill and gives better hole dia. control..
                  #221013
                  Muzzer
                    @muzzer
                    Doesn't say (or look like) emery cloth – just a bit of thing cotton sheet perhaps.
                    As ASF suggests , I guess it's damping out the vibrations that result from the bit dancing about while cutting a non-circular hole. Just enough drag to dampen its enthusiasm. The drill centre must be jigging about nicely when it's making those trianguar holes.
                    Edited By Muzzer on 14/01/2016 08:29:48
                    Edited By Muzzer on 14/01/2016 08:33:52
                    #221020
                      Posted by Muzzer on 14/01/2016 08:12:10:
                      I've not tried it with normal drills, but that certainly calms-down chattering countersinks.
                      Edited By Michael Gilligan on 14/01/2016 08:49:23
                      #221022
                      Martin Kyte
                        @martinkyte99762
                        I would concur with the last two posts with the additional comment:-
                        It's about getting an accurate start to the hole. Once that has been achieved the hole progresses correctly. Basically it stops the tips of the cutting edges grabbing and throwing the drill off centre. Once this has happened the drill follows the odd shaped hole all the way through.
                        regards Martin
                        #221024
                        jason udall
                          @jasonudall57142
                          Not certain
                          My belief is that in part damping and support for the point of the drill…stabilization.
                          Its old..saw it listed as tip-dodge..in 1800’s book..old then…
                          #221048
                          David Clark 13
                            @davidclark13
                            Just drill hole a bit undersize and finish with a slot drill.
                            #221051
                            Chris Evans 6
                              @chrisevans6
                              That was one of the first things shown to me when I started my tool making apprenticeship in 1963. We never questioned how it worked, just applied the method of a bit or worn emery cloth.
                              #221060
                              Gordon W
                                @gordonw
                                I've always assumed the cloth or emery cloth fills the flutes up, so creating a "solid" tip that works a bit like an end mill.
                                #221093
                                Dinosaur Engineer
                                  @dinosaurengineer
                                  The method will work with ordinary cloth but works better with fine to meduim emery cloth.
                                  Edited By Dinosaur Engineer on 14/01/2016 15:44:52
                                  #221106
                                  mick
                                    @mick65121
                                    It fills the flutes and stops the web wandering when it starts to bite, use worn out emery tape folded double with the grit faces inwards, the resulting hole will be round but slightly oversize.
                                    #221112
                                    Nigel McBurney 1
                                      @nigelmcburney1
                                      I was shown this trick many years ago,the method was to use a small piece , rag folded over and over to get 8 thicknesses, works well on thin sheet ,the rag fills up the flutes and makes the drill work like a reamer,
