I am sure we all agree that safety is paramount, and that nobody should touch a safety-critical system if they don’t know what they’re doing. I also take Clive’s point about certain safety-critical electronic components – (but my reply to that is why keep it secret ? Why should I have to spend £2,000 on a complete new boiler and all the disruption of having one installed, when a £2 component on the control board has failed ?).
During my house ownership, I have seen the “standards” of many supposedly “qualified professional engineers”. Slap-dash installation of ceiling down-lighters, electrical junction boxes and of pipe plumbing that I have seen has led me to the conclusion that some “engineers” either must have false qualifications or pay absolutely no attention to them once ‘qualified”, simply in order to complete a job as quickly as possible. A ceiling joist weakened by being half cut through with a hole saw in order to mount a down-lighter was one particular example, when with some thought and careful measuring he could have moved the fitting 2 inches to miss the joist.
Another was a floor joist half cut through to route a shower drain – and in that example the floor joists were glued wooden I-beams with knock-outs provided in the centre web for pipes etc, but the idiot who installed the drain had ignored those and cut right through the top rail of the I-beam, because it was easier and quicker for him.
I found that a faulty boiler in one house was full of copper particles and filings from cutting pipes etc, and which should have been fully flushed out before commissioning the boiler, but which were left in the system, where they eventually jammed half the water valves in the boiler.
The main boiler hot feed pipe in this house was almost completely blocked from corrosion products because no anti-corrosion solution had been added to the system. Both installed by “qualified gas-safe” central heating installers…………yeah, right.
I have also seen the most ridiculous plumbing pipe tangles with no thought given to water flow or subsequent maintenance access to components.
As such, I object to paying eye watering amounts for some gormless white van man to install something, when I know that my life-long engineering experience, knowledge, attention to detail, and safety, will produce superior results – even though he might have a specific qualification, and technically I don’t. (Although I do have qualifications for electronics and safety, and I certainly have a lot more knowledge and competence).
I also object to paying huge mark-ups on new equipment and components supplied.
