How do you solder brass cones/nipples onto copper pipe
Home Forums Beginners questions How do you solder brass cones/nipples onto copper pipe
Viewing 17 posts - 26 through 42 (of 42 total)
  • #157579
      On larger sizes of pipe, the Sievert Cyclone Burners work very well
      … although seeing the current price was a shock.
      Does anyone know of a "micro" size burner with a similar wrap-round flame?
        Too late to edit previous post …
        Here is the smaller of the two Sievert Cyclone Burners [19mm dia.] … This one is ideal for domestic plumbing; but something half that diameter, or a little less, would be nice for small work.
          They do make a 14mm cyclone but I think it fits a different torch body
          #157604
          Mark P.
            @markp
            Silver soldering is not a black art as people imagine, here is my fool proof method.
            1. Apply flux paste to pipe,
            2, Insert pipe into nipple.
            3. Heat pipe just above nipple,use slightly carburising flame(soft).
            4. Apply solder to job, don't melt solder with flame let the temperature of the job melt it. Use just enough to do the job,(remember silver solder is expensive) I would recommend using the smallest rod you can I find 455 at .7mm ideal for nipples.
            5. When solder has solidified dunk in DILUTE sulphuric acid to remove flux, wash in water.
            Hope this is of use to you. Mark P.
            #157610
              Posted by JasonB on 11/07/2014 12:38:17:
              Jason
              Thanks, but that's still rather big compared to what I had in mind.
              For small work; I am intrigued by the possibilites of Resistance Brazing … I have a suitable Transformer, so making some handpieces is definitely on the ToDo list.
              Edit: Just found this old but useful info. from Johnson Matthey
              Edited By Michael Gilligan on 11/07/2014 15:18:40
              Edited By Michael Gilligan on 11/07/2014 15:34:34
              #157622
              JA
                @ja
                Just a thought. Many years ago I tried to solder gunmetal oil banjos onto copper tube using some scrounged high temperature solder. The oil banjos kept melting as soon as I applied solder. Oh the joys of metallurgy – eutectics and all that. As soon as I tried ordinary "easyflo" solder I had no problems.
                JA
                #157661
                GaryM
                  @garym
                  Posted by Neil Wyatt on 10/07/2014 10:06:12:
                  I've got a cook's blowtorch that cost about £8 in Aldis. Ideal for this sort of task. Also very handy for lighting larger torches as it has a piezo igniter built in.
                  I also use one of the cook's blowtorches to light the propane torch. I found I kept blowing out matches and tea lights even with the gas turned down. With one of these little blowtorches you can turn it on, ignite the flame and turn it off again with one hand. Also handy if you fancy a Creme Brulee in the workshopwink
                  Gary
                  #157663
                  julian atkins
                    @julianatkins58923
                    marcus bowman and mark p. have provided excellent advice. i've silver soldered hundreds of cones/nipples to small copper tube in the last 31 years and never had a problem.
                    you need to know what the flux looks like when the job is up to temperature! a diffused light helps gauge the temperature of the parts being heated, but not so dark that you cant see the changes in the flux. ive a full set of sievert burners on my propane, and for small jobs avoid the very small burners with a very concentrated flame. i go up a few sizes to a medium sized burner for a soft gentle overall flame.
                    when the flux changes to the correct state you have only a few seconds with small bits such as this to apply the silver solder! 'flash' and done!
                    cheers,
                    julian
                    Edited By julian atkins on 11/07/2014 23:48:33
                    Edited By julian atkins on 11/07/2014 23:48:48
                    #157681
                    Les Jones 1
                      @lesjones1
                      Mark,
                      I think you need to find someone that lives close enough to you to give you a demonstration of how things look when silver soldering. (Estimating temperature, flux flow and silver solder flow.) I think silver soldering is just like learning to ride a bike. Once you can do it it seems so simple. If you are not prepared to give an idea of your location so someone can offer to show you the technique then go to one of the shows where cupalloys have a stand. They may be doing a demonstration.
                      Les.
                      #157689
                      Keith Hale
                        @keithhale68713
                        Mark,
                        You will certainly find CuP Alloys at Bristol, Midlands, Ally Pally, Harrogate, Bakewell, Spalding.
                        Keith
                        #157696
                        michael howarth 1
                          @michaelhowarth1
                          Keith (CuP Alloys) ….when are you at Spalding?
                          Mick
                          #157698
                            One tip, if you are melting things, if silver soldering outside, always do it in good shade.
                            Phil H 1
                              @philh1
                              Posted by Marcus Bowman on 11/07/2014 08:18:00:
                              Then there's the oxy-acetylene… which inevitably just melts small jobs. Wonderful tool, but not for nipples.
                              Marcus, just for info – you really can use oxy acetylene for tiny jobs with a small nozzle. Silver soldering brass nipples onto copper tube would be no problem. It is just down to the flame size being used.
                              Phil H
                              #157729
                              paul rayner
                                @paulrayner36054
                                If you live close enough to call, as I am giving up my shop soon, I will give you what you need, but I am not into posting things.
                                thats very generous of you. you should be on the outstanding service thread
                                regards
                                paul
                                #157766
                                lancelot
                                  @lancelot
                                  Hi all, Marcus I contacted one of Loctites technical gurus last week and explained that i was experimenting with loctite 603 ,using it to retain the usually silver soldered nipple (sleeve)on to the end of a pipe..I gave the dimensions of pipe ,steam pressure and he worked out that it was feasible …603 held to 150*c but as he could not give the temp at the actual nipple , he would much prefer to use 648 loctite as it goes up to 175* c…so i said i would try that and let him know the results properly prepared it should be a good job…
                                  The whole idea behind this experiment is not that i am not able to silver solder a nipple on to a pipe…I most certainly can and make a good job of it …BUT…when my hands are tremoring with the effects of Parkinsons …Forget it….If i can verify the idea does work safely i will use it.
                                  All the best for now.
                                  John.
                                  #157794
                                  Marcus Bowman
                                    @marcusbowman28936
                                    Yes; Loctite technical staff are very helpful. I do know that Loctite works best when the parts are pushed together under a light interference fit, so it may be possible to machine the nipples for that condition to apply. The idea is to exclude air, and it seems this works best when the film of adhesive is sheared as the parts go together, leaving the bond to be made by very thin layers of adhesive which are left in the microscopic interstitial spaces between the components. I always thought I should leave a little clearance for the adhesive, but, having taken advice about replacing a press fit between two components by using Loctite, the advice I as given was t go for a light press assembly, having first coated the mating surfaces with Loctite. Worked extremely well, and the components are still together, despite heavy loading of the joint.
                                    In the case of a nipple, I would guess that a light finger-push fit is what would be required.
                                    It might also be a good idea (and a slight complication) to ensure the tube was round and of the correct diameter, perhaps by inserting a rod, and squeezing the outside of the tube very lightly between two halves of a hole. Clamping two rectangular blocks together, and drilling a hole down through the joint would give an accurate former.
                                    I think all of this is, as you say, a very interesting experiment. It also highlights how developments in adhesives challenge our preconceptions.
                                    Marcus
                                    #157796
                                      Just a reminder …
                                      Copper is a catalyst for the curing action of Loctite anaerobics.
                                      When pushing a close-fitting tube/nipple assembly together … you might be surprised how quickly it bonds.
