How do I tell stainless steel from silver steel ?
Home Forums Stationary engines How do I tell stainless steel from silver steel ?
  • #3222
    Brian John
      @brianjohn93961
      It all looks the same !
      Brian John
        @brianjohn93961
        I ordered a number of pieces of 6.35 mm round bar stock in both stainless steel and silver steel which arrived today. Nothing is labelled so how do I tell the difference between the two materials ? I cannot discern any visible difference between them ; it all looks the same to me.
        #162098
        David Colwill
          @davidcolwill19261
          A magnet is the obvious first thing but not all stainless is non magnetic.
          Regards.
          David
          #162099
            Silver steel is magnetic and the majority of stainless is not.
            The silver steel is also likely to be 13" long and the stainless 300mm/12"
            Silver steel will go rusty if you leave it out in the rain but thats not teh best way to find out whats what
            Edited By JasonB on 29/08/2014 10:59:02
            #162100
            David Colwill
              @davidcolwill19261
              Spark testing may help.
              Regards.
              David
              #162102
              john kennedy 1
                @johnkennedy1
                If you can spare a bit, heat an end of one piece to cherry red and dunk it in cold water. If its too hard to file,its silver steel.If you can,its stainless. I think Jason's suggestion of length would be the best non destructive way of telling.
                #162103
                Johnboy25
                  @johnboy25
                  Brian. Somewhere in the grey matter I think I can remember the same question being asked too many years ago to remember and I was told that stainless steel can be tested with copper sulphate solution. Stainless doesn't take on a copper deposit. Not sure if this applies to the magnetic grades of stainless steel. Perhaps someone can advise on this as I'm not a metallurgist. Something to experiment when I can get some copper sulphate crystals!
                  Reminds me of those days when I had a Lotts chemistry set!
                  Vic
                    @vic
                    I use Gun Blue for some things so a quick wipe on them would tell them apart. I'm told you can blue stainless steel but the stuff I got from the shop won't touch it!
                    #162107
                    Clive Foster
                      @clivefoster55965
                      From a previous thread started by Wolfie on 14/10/2011 "Silver or Stainless" :-
                      http://www.engineeringtoolbox.com/identification-stainless-steel-d_383.html
                      has data on identifying different types of stainless. Presumably you know what type of stainless you ordered so the table should tell you if its magnetic and what sort of sparks to expect.
                      #162108
                        Just one thing to remember when grinding other metals is don't get the sparks anywhere near the stainless as when they hit it they will weld themselves to the stainless steel and you will then wonder why it is rusting.
                        Ideally also use a different grinding wheel/cutting disc for stainless as any deposits of ferrous metal embedded in the abrasive can again transfer to the stainless
                        J
                        #162109
                        Phil P
                          @philp
                          You might also find that your 1/4" stainless is a few tenths of a thou smaller in diameter than the silver steel, that is unless you have bought ground stainless.
                          Phil
                          #162110
                          Brian John
                            @brianjohn93961
                            Thank you, the silver steel is magnetic. The stainless is not. They are all slightly different lengths so nothing to go on there.
                            #162153
                            thomas oliver 2
                              @thomasoliver2
                              It is my experience that silver steel apart from being sold in 13in. lengths is always no more than 0.001 ins below size, and mild steel and stainless will normally be 0.002 to 0.003 in smaller at least. Ground stock will usually be spot on for size.
                              #162155
                              Roderick Jenkins
                                @roderickjenkins93242
                                I think the days of Stubs silver steel in 13" lengths are largely gone sad. The silver steel I've bought of late has been cut off from longer bar.
                                Cheers,
                                Rod
                                #162203
                                Ian S C
                                  @iansc
                                  Rod, did your silver steel look a bit blue at the end where it was cut, I think it some times gets cut off with an abrasive cutting wheel, then cooled rapidly, leaving a bit at the end dead hard.
                                  Ian S C
                                  #162204
                                    I know at least a coupe of suppliers who do imperial in 13" or 39" lengths and metric in 333mm or 1m so its still about. (Make that 3 if you count the classifieds here)
                                    Maybe they are just cutting the longer 39"/1000mm bars down manually to approx 1/3rd
                                    Edited By JasonB on 30/08/2014 14:19:23
                                  Home Forums Stationary engines Topics
