How do I make a simple, flat torsion spring? (in stainless?)
Home Forums Workshop Techniques How do I make a simple, flat torsion spring? (in stainless?)
Viewing 25 posts - 1 through 25 (of 29 total)
  • #270468
    Russ B
      @russb
      I need 8 simple springs, they are not coil springs which push or pull along their axis. They are torsion springs which act tangential to their coil, but I need zero coils as the spring travel is less that 0.5mm and each leg is around 40mm long. so basically just a 40mm vee shaped piece of wire with around 5mm of the ends bent up at 90 degrees to locate in some holes. The wire diameter will be around 1mm or so
      Would anyone be kind enough to educate me on what sort of wire I should be buying, and how I could heat treat it. I would love them to be stainless or somehow protected against corrosion but this isn't essential.
      The springs are for my cars brake pads, they just apply a small amount of separation force to the pads to stop them rubbing on the disk – I don't have any at the minute and its fine, many cars just dont! They've rust and snapped and not having them makes my brakes whistle and whine when I roll up to a stop or turn on full lock.
      I can buy replacement springs but a set will cost me £24 which seems like daylight robbery. I feel like I could bend all 8 with a pair of small pliers within about 60 seconds and harden them in even less time – I gather I would then draw out the temper a little and jobs a good un – but I've never made a spring, so I'm guessing here, and I don't know what material to use. Even if it ended up costing me the £24, it would be educational.
      Russ B
        @russb
        #270479
          Music wire.
          #270481
          Bernard Wright
            @bernardwright25932
            Search 'eBay' for 'Spring/Music/Piano Wire', I've bought different sizes off of there, quite reasonable prices including P&P
            #270482
            David Jupp
              @davidjupp51506
              Not a direct answer – it may be worth trying an automotive brake specialist, likely to be cheaper than car dealership for such obscure items.
              #270523
              Jon
                @jon
                Cheaper than thought it would be £4 comes hardened and tempered.
                HOWARDT
                  @howardt
                  Jon link looks like instrument wire (piano, harpsichord) not solid piano wire as in spring steel. May be wrong and it's a trick of the camera pixels but worth a check.
                  #270555
                  Paul Lousick
                    @paullousick59116
                    Hi Russ,
                    Solid piano wire is probably better option but try MIG welding wire as a cheap alternative.
                    Paul
                    #270573
                    duncan webster 1
                      @duncanwebster1
                      My local model aeroplane shop sells piano wire in a range of sizes. Probably too thin for you, but I've bought stainless wire for making springs from dental technicians in the past
                      Edited By duncan webster on 08/12/2016 01:54:00
                      #270588
                      Russ B
                        @russb
                        Ok thanks, plenty to look in to there.
                        As for mig wire, I wouldn't expect to get much of a spring of out that! Am I missing something here?
                        Music wire I've bought before in 4mm for a miniature T bar. Do I need to heat treat it to give it its spring or is already treated (and so, should I heat it up where I intend on bending it so it doesn't snap?)
                        Sorry for the novice questions here, I've not really any knowledge worth retaining in the field of heat treating and especially springs (I could make a centre punch and harden its tip, and I can heat treat silver steel but that's about the limit of my basic knowledge (and the 2 are basically the same thing)
                        #270594
                        Dusty
                          @dusty
                          Piano wire is hardened by the drawing process, if you heat it you will destroy the temper and you will never get it back, many have tried and failed. It can and usually is bent cold. Do not hit the bend in order to complete it as that is a sure way to induce a crack. I would ask myself what have I got most of 'time or money' I feel sure your 60 seconds is very optimistic and it will take you far longer.
                          #270597
                          Russ B
                            @russb
                            Dusty thanks for the info, that's great.
                            As for time and money, the answer is, I take great pleasure in learning and achieving things like this, tinkering is my hobby I guess.
                            #270598
                            colin hawes
                              @colinhawes85982
                              It may be possible to unwind a suitable coil spring for the material. Colin
                              #270615
                              Emgee
                                @emgee
                                Russ B, 18swg piano wire from your local model shop, next size up is 16swg which is 1.6mm thick.
                                Emgee
                                #270618
                                Windy
                                  @windy30762
                                  I have used Tig stainless 316l for various applications it seems springy as I found when making those fishing lures.
                                  #270658
                                  Russell Eberhardt
                                    @russelleberhardt48058
                                    I don't know how critical the diameter is but 19 swg is just 1.016 mm if you can get it. 18 swg might be too thick.
                                    Russell.
                                    #270752
                                    Jon
                                      @jon
                                      As far as I am aware music wire is solid, comes ready hardened and tempered. Can be cold bent meaning it loses its memory and therefore not the greatest steel used but poor quality.
                                      If heat it up guarantee problems ranging from collapsing to breakages and would be either hit and miss through trial and error.
                                      It will easily take a 90 degree cold bend as a tag either end.
                                      Make the coil first leave ends long, cut to length then bend the tags about 2 mins each on conservative side after a practice and setup.
                                      #272905
                                      Nick Hulme
                                        @nickhulme30114
                                        Posted by Jon on 08/12/2016 22:57:06:
                                        How it behaves is how it was designed to behave, if a steel had been used which was incapable of being bent past it's yield point then it would not be fit for purpose. Coil and torsion springs from music/piano wire give excellent performance and life, it's obviously good quality steel which does exactly what it's designed to do.
                                        – Nick
                                        #278401
                                        Jon
                                          @jon
                                          Nick if you were making it correct you would harden and temper after!
                                          How it behaves is material quality as in grade, hardening and tempering. Of which theres spring steel grades and theres spring steel grades of variable quality.
                                          Just so happens this low grade spring steel used is not very hard or that springy compared to better quality and can only be hardened and tempered up to a limit hence it collapses past its yield. Fine for products that don't require much use or easy to make products without the necessity for harden and tempering which most will get wrong and come out anything from too soft to brittle.
                                          Wondered why a brand new proper spring softens after a break in or first use?
                                          #278419
                                          KWIL
                                            @kwil
                                            Russ,
                                            What make and model of car?
                                            They normally last as long as the pads and new pads need new springs.
                                            #278420
                                            Muzzer
                                              @muzzer
                                              Posted by Jon on 17/01/2017 11:50:38:
                                              Hmm, that comes as news to me, as technical director in a company that designs and makes many hundreds of thousands of springs every year for demanding automotive applications. Incidentally, you don't need to harden and temper materials to make springs from them. As long as you keep within their elastic limit they will work fine – and they don't even need to be made of "spring" steel.
                                              #278425
                                              Mark C
                                                @markc
                                                Muzzer, It is possible what he means is that they take a set (perhaps KWIL can confirm? ). Being involved in spring manufacture for automotive then you will undoubtedly been aware of the term "scragging" which refers to loading a spring element cyclically a number of times after manufacture to take away the initial set the end user would see otherwise.
                                                Mark
                                                #278442
                                                An Other
                                                  @another21905
                                                  I sympathise with the concern about the apparent cost of these springs, but this sounds very dodgy to me – do you have any parameters on these springs – under what conditions should they be able to work and so on? and to risk untested 'home-made' kit as part of the brakes on your car. Hope I don't live anywhere near this you. Bite the bullet and buy the correct parts, rather than take the risk.
                                                  #278443
                                                  RonMc
                                                    @ronmc
                                                    Hugh Craig Harpsichords is a good fast supplier of music wire, all gauges.
                                                    http://stores.ebay.co.uk/hughcraigharpsichords/
                                                    #278472
                                                    Nick Hulme
                                                      @nickhulme30114
                                                      Obviously you need to write in to Machinery's Handbook and complain that their extremely useful guides for mandrel sizes for winding compression and tension springs from piano wire have been misguiding engineers since 1914.
                                                      Alternatively you could buy a copy and learn how to wind some springs without heat treatment
                                                      There is a limit to the utility of some piano wire spring sizes but you should not be under the impression that winding soft and heat treating after is the only way to skin this cat, just because it's the only way familiar to you 😀
                                                      I make some gun springs from Piano Wire because they work better and last longer than OEM springs so this is by no means a simple subject and there is no one right way to make a spring without testing,
                                                      – Nick
                                                      Edited By Nick Hulme on 17/01/2017 19:02:59
