If this spindle is greasable, you should not use sealed bearings! There is no sign of any grease contamination, and I am assuming there is a grease nipple. If you fit sealed bearings you will not be able to grease them (you will note that these bearings are absolutely full, and have not failed! If you have already bought sealed bearings, take the seals out on the inside so that grease from the grease nipple (if fitted) goes into the bearings. You will be shocked as to how little grease the manufacturers put in.
Incidentally, the "seals" are not seals in the sense of a lip seal, they are merely dust covers, and do not keep fine dust out of the bearings anyway. There are a couple of videos on the tube showing garden tractor grass decks (Toro i think) which have been suffering premature bearing failure despite having grease nipples and being regularly greased. When stripped it was revealed that the manufacturers had fitted sealed bearings to a greasable spindle, and all the greasing was a waste of time!
Pedants, I am not interested in what the manufacturers say, they are in the business of selling bearings, or the "half full, or third full" arguments. I have been in hands on engineering all my working life,I have fitted many thousands of bearings, I have always filled bearings full both sides, and the only time bearings I have fitted have failed was when I started to fit "sealed for life" bearings. Any bearing supplied with a grease nipple will be full all the time, provided it is greased at the recomended intervals, and proper greasing replaces the grease by forcing the old grease out! It is noticable that modern bearings are not going anywhere near to outlasting the old tech bearings I was taught to fit in 1967!
Phil
