The post WW2 automatics were basically epicyclics where which brake band was operative was controlled by the manifold vacuum. hence the vacuum capsule. Road speed was sensed from the pressure produced by an oil pump within the transmission, and driven by the output shaft.
The Borg Warner 35 was relatively unsohisticated and in some applications could produce quite a rough ride!
Renauklt sophisticated this in the 70s, using electrical sensing of road speed and load by using a small generator, where the output was moderated by shading between stator and rotor, to snse throttle poisition (implying load )
A torque convertor was a development of the fluid dlywheel, wher a set of intermediate vanes produced torque multiplication.
Matching a torque convertor to a particular engine and installation could be quite a task. At Rolls – Royce, both the car and oil engine divisions employed specialists to calculate the best match. O E D used Twin Disc transmissions, made under licence at Crewe.
A torque convertor required fewer gear ratios. than a fluid flywheel, because it already provided torque multiplication
Unsynchronised gear boxes were used in commercial vehicles until the late 60s, although semi automatic transmissions were available. The Leyland "Moncontrol" was direct air control of the brake bands rather than the electromechanical system where the the tiny gear lever controlled solenoid valves which fed air to the approriate air cylinder to apply or release the required brake band.
The London Transport Routemaster used a more sophisticated electcal contol of the gear box, supercediung the fluid flywheel and epicyclic box prviously used on the RT and RTLs.
An unsynchromised box provided a lighter gear change than a synchromesh box, even if you double declutched any way!
Used cortrectly, a cluch brake (Clutch stop ) upward chnages could be made as fast as or faster than a syncromesh box!
Relaints used unsynchronished boxes into the 50s and 60s.
As Peugeot said of the unsynchronised gear box "C'est brusque; mais sa marche"!
