How concentrated should I make a citric acid pickle ?
Home Forums Workshop Techniques How concentrated should I make a citric acid pickle ?
Viewing 25 posts - 1 through 25 (of 30 total)
  • #163355
    Brian John
      @brianjohn93961
      I will be having a go at hard soldering a small boiler soon. I have bought some citric acid from the supermarket (75 grams). How concentrated should I make the pickle to neutralise the flux ?
      Brian John
        @brianjohn93961
        Neutralising the flux after hard soldering.
        #163383
        Rik Shaw
          @rikshaw
          Jon – From my school chemistry lessons a "few" years back a saturated solution can only be achieved by boiling.
          Rik
          #163384
          Eugene
            @eugene
            Depending on the temperature 75 grams of citric acid will only make a saturated solution of around 100 ml of water. I'd just cover the part and tip in all the citric you've got . Suck it and see, then if you think a higher concentration is needed, get some more acid.
            Eug
            #163385
            Eugene
              @eugene
              Rik,
              Solubility is indeed temperature related, normally the hotter the solution the higher the solubility. So at 20 C you can get a saturated solution of material X but at 40 C you can get more to dissolve. So boiling doesn't really come in to it.
              Eug
              #163388
              John Bromley
                @johnbromley78794
                The last boiler I did was about 6 inches long and 2 inches in diameter. To pickle it I used 200g of citric disolved in 500ml of hot water. This worked very well, taking 20-30 mins to bring it all back to shiny copper.
                clivel
                  @clivel
                  Is there any reason not to use white vinegar?
                  A few weeks ago I needed to silver solder some copper bits together and not having any citric acid to hand I grabbed some white vinegar from the kitchen which I arbitrarily decided to dilute 50/50 with water. The parts came out spotless after about 30 minutes or so.
                  Edited By clivel on 11/09/2014 23:14:14
                  Edited By clivel on 11/09/2014 23:14:32
                  #163411
                  Muzzer
                    @muzzer
                    Wikipedia (never wrong!) quotes the following solubility of citric acid in water:
                    117.43 g/100 mL (10 °C)
                    147.76 g/100 mL (20 °C)
                    180.89 g/100 mL (30 °C)
                    220.19 g/100 mL (40 °C)
                    382.48 g/100 mL (80 °C)
                    547.79 g/100 mL (100 °C
                    Sounds as if lemon juice is about 0.3 mol / litre. The molecular mass is 192g / mol ie so presumably lemon juice for comparison is only about 6g/100mL(?) ie about 4% concentration at room temp. Yes, it's years since I did any chemistry apart from making big fireworks.
                    Merry
                    #163413
                    Brian John
                      @brianjohn93961
                      1. So you do not have to scrub the parts… you just put them in the pickle and if the solution is strong enough then they will come up shiny ?
                      2. Yes, I was wondering about white vinegar too ? It would be much safer and easier to obtain than sulphuric acid and much easier to use than citric acid.
                      Edited By Brian John on 12/09/2014 04:57:15
                      #163429
                      Raymond Hodges
                        @raymondhodges20973
                        I use a 25% viniger essence solution bought in a botle from the local supermarket.
                        Left in this solution a couple of hrs it comes out nice and clean.
                        The parts must be thoroughly washed after this treatment to avoid corrosion.
                        Ray
                        PS I only use this on Brass and copper parts.
                        #163522
                        john jennings 1
                          @johnjennings1
                          Citric acid is so soluble that a saturated solution at room temperature will consume vast quantities of acid and the resulting syrup will be very messy and difficult to handle.
                          I would have thought that 5% solution i.e. 50g per litre ( or 1 ounce per pint ) would be quite strong enough for purpose and If you want a large volume to totally immerse the boiler you would probably find a more dilute pickle would work if hot. Although citric acid won't give off an acid vapour – leading to mega rust on steel – I would prefer not to store the solution which is another reason for making it over strong.
                          john jennings 1
                            @johnjennings1
                            Posted by john jennings 1 on 13/09/2014 17:09:56:
                            What a load of claptrap.
                            Sorry I'm not sure what the claptrap is.
                            Using Muzzers figures a pint of warm (30 C) saturated citric acid solution would need over 2lb of solid acid.
                            This seems a really awful lot and if the solution evaporates or cools it will deposit excess solid acid.
                            The action of citric acid is quite complex partly due to the acidity of the solution (which at higher concentrations won't be proportional to the concentration) and partly forming soluble citrate complexes with, in this case ,copper atoms/ions.
                            End of chemistry tutorial for today!
                            However I guess it is a matter of experiment : I would still begin with weaker solutions.
                            mike T
                              @miket56243
                              Brian, I tend to agree with John, Over the years I have found a weaker citric acid solution to be better for cleaning and de-scaleing silver soldered joints in steel and brass. It works slowly and you often need to leave the silver soldered assembly in the solution over night.
                              #163591
                              clivel
                                @clivel
                                Posted by Bogstandard2 on 13/09/2014 19:40:42:
                                Mix in some sugar and you would have the beginnings of lemonade, only feed it to the mother in law when it is exhausted though.
                                I don't know about lemonade, but when we were kids we used citric acid, bicarb of soda, and icing sugar to make our own sherbet powder.
                                I guess it is safe enough as we are all still here.
                                #163635
                                Ian S C
                                  @iansc
                                  When I was nursing, it was one of the jobs as night nurse to descale the sterilisers on the wards, we used citric acid in its industrial form, it was gray in colour, and some times you had to break up the lumps, the sterilisers were steam heated, I went to another Hospital that was all electric, we tried the citric acid, it took the scale off, uncovering holes in the elements, new elements.
                                  Another place to find it is an agricultural chemical supply outlet.
                                  Ian S C
                                  #217107
                                  Brian Abbott
                                    @brianabbott67793
                                    Hello all, having read through this I am still a little unsure to the mixing ratio of citric acid to water to make a copper cleaning solution, could anyone help me ?, thanks in advance
                                    #217120
                                    Lynne
                                      @lynne
                                      Have a look at CupAlloys web site , best brazing practice, they tell you there.
                                      #217122
                                      Brian John
                                        @brianjohn93961
                                        I buy my citric acid from the supermarket (cooking section). I mix about one teaspoon per glass of water….that should give you an idea.
                                        Edited By Brian John on 20/12/2015 06:14:26
                                        #217127
                                        Brian Baker 2
                                          @brianbaker2
                                          Greetings Brian, citric acid is a very safe way of pickling you valuable boiler.
                                          You definately do not need a strong solution, as already explained, it chemistry becomes counter productive when you have a strong solution. Try about 1 heaped table spoonful of acid crystals to a gallon of water, and see how well this works, you can always add a little more if needed.
                                          Like all chemical process, the cleaning operation is much more effective when warm, and if you allow your boiler to cool so that it only just steams when you put it in the solution, this will warm it nicely.
                                          Beware of thermal shock damage to silversoldered joints when quenching them, and allowing a short cooling period for the heated boiler to come down to somewhere below 200 degrees is a very good idea.
                                          I dislike "vinegar" products, because some of them contain complex sugars & starches which can be difficult to remove easily, and can affect subsequent soldering operations. Citric acid salts are all easily water soluble.
                                          It can be purchased in bulk from home brew suppliers, or from a well known auction site.
                                          Good luck with your boiler making, not enough of this happening in the M E fraternity in my opinion.
                                          Another Brian
                                          #217128
                                          Brian Baker 2
                                            @brianbaker2
                                            Forgot to say that the residues are easy to dispose of.
                                            Brian B
                                            #217129
                                            Keith Hale
                                              @keithhale68713
                                              Citric acid is safe to use and store.
                                              It tastes foul! Your pets and grandchildren will only taste it once on their learning curve! But it will not do them any harm
                                              Simple guide.
                                              Suggest 10gms/litre or 50gm sachet /gallon of water.
                                              Merry Christmas and Happy New Year to all
                                              Glen, Jane, Keith, Shaun
                                              #217135
                                              IanT
                                                @iant
                                                I use citric acid to remove soldering and brazing flux and (to some extent) scale & rust from bits.
                                                I've never worried too much about "how much" – the main problem (in practice) is to be able to cover the part if it is large or awkwardly shaped. For these parts I first find a suitable (e.g. not too big) container – I have a few different shaped/sized ones (an old plastic bowl, ice cream containers, cut down milk bottles and a old home brew 'tub'  ) and fill it with hot water just sufficient to cover the part. Dependent on the amount of water used (which I simply guess), I put in about a heaped teaspoon per pint.
                                                I then fish the part out after an hour or so and give it a bit of a scrub with wire wool and/or pick at any flux with a 'scratcher' (depends to some extent on the existing state of finish). Sometimes this is sufficient but usually it needs more time in the solution – but I keep checking fairly regularly and scrubbing/picking at the worst of the flux. So to my mind a fairly dilute solution works fine but what you must to do is monitor the part for progress and not leave it in over long. Having said that, I will often leave rusty steel parts in solution overnight – it's the non-ferrous stuff I watch more closely
                                                I used to buy small packets of citric acid (50-75gms) from chemists but then discovered that for just a bit more I could get 1kg bags from eBay (look for Citric Acid & Indian Cooking). I use old plastic milk bottles to keep & store used citric solution and it seems to work fine (any 'muck' settles to the bottom) if I pour off the clear part of the solution and then top it up & cover the part with hot new solution… . Not too much science I'm afraid but it seems to work for me.
                                                Hope this helps.
                                                IanT
                                                Edited By IanT on 20/12/2015 10:09:18
                                                #217157
                                                Ian S C
                                                  @iansc
                                                  Also look at Home Brew Shops. I use a bit stronger, about one desert spoon per litre.
                                                  Ian S C
                                                  #217162
                                                  mechman48
                                                    @mechman48
                                                    Thanks for info' IanT & Ian SC
                                                    Have wondered abut this aspect for a while; have a couple of packets of Citric Acid from home brew shop for future use, now I have some idea of ratio.
                                                    George.
                                                    #217381
                                                    Brian Abbott
                                                      @brianabbott67793
                                                      Thanks all for taking the time to reply,
                                                      not had chance to try the suggested mix but hopefully will do over Christmas,
