Posted by Dave S on 14/01/2022 17:52:14:
Are you covering the abs with a layer of rubber, joining abs to rubber to something else?
Geometry of the joint may make a difference to recommendations.
Do you need the glue to be thin as possible, or is a thick glue line acceptable?
Often rubber bits on plastic are 2 shot moulded – the plastic is molded the loaded into another mold and the rubber injected. The surface design of the plastic substrate and the heat assist in a bond.
More info will help a better answer, but in the absence of it (cos it’s bound to be secret and “not relevant&rdquo
I would look at a SikaFlex. Not going to set in 5mins tho. If quick set is actually required then an impact modified cyanoacrylate is where I’d start.
I am using strip of rubber to create a hinge between two plates of ABS.
It doesn't need to be super-thin. I suppose up to 0.2mm thickness would just about be okay.
Yes, absolutely. This is a model for exactly that.
Since asking the question I have been experimenting further, with various glues. I am finding them all extremely hard to apply evenly and the result quickly gets exceedingly bumpy and messy.
But in my experience, what has been an absolute game-changer, for producing really smart results, is if one can use some sort of glue-tranferring tape, so long as it's thin enough.
e.g. This stuff "3M 9088-200 High Performance Double Coated Tape"
https://www.3m.co.uk/3M/en_GB/p/d/b40070391/
It certainly is amazingly tacky! (i.e. sticky) The results can be seriously smart, and with care it is slightly (but not very) repositionable, in that with patience you can generally peel it back off a solid surface.
However I suspect that it doesn't ever form a solid bond. And so when the hinge is under long-term, sustained pressure, particularly if the item is accidentally left in direct sunlight, I suspect that it may fail… despite what the specs claim!
J
