Posted by Barrie Lever on 21/07/2019 11:20:51:
Once you own a surface plate or surface table you will wonder how you got on without one, look on Ebay for a good condition second hand item.
I purchased a second hand high quality Swedish made granite table 900x600x100 thick on a stand for £360.00 on Ebay.
B.
Not in my workshop! I feel it would be a waste of space and £360. I'd cheerfully buy one if it was going to be used, but I rarely need such a thing. If Andrew only wants one to sort out his mini-lathe, that's big money for one job.
When I need a flat surface a lump of kitchen worktop is generally 'good enough' or a sheet of float glass when better is needed. Float glass is close to being optically flat. The main disadvantage of worktop and glass sheet is they bend when overloaded, so care is needed in use. (Bending is probably the reason why the stands used to support granite plates are 2x or 3x more expensive than the plate itself.)
For precision work a surface plate must be calibrated. Read all about it here. More expense!
My main reason for needing a flat surface is to transfer a position accurately from one object to another with a scriber block or height gauge. Doesn't happen often. I can't remember ever needing to make a flat surface flatter than can be managed by my mill or by facing-off on my lathe, so scraping is off my agenda. Ignorance is bliss – am I missing any other uses for a surface table?
