Hi Ian, Sorry I missed you today but you got to see my messy workshop. Sometimes the tools find their way back to the right place and after a good tidy up it looks a lot better. Funny how you know my wife from bowls umpires, small world isn’t it. If I don’t see you before I will be in Darfield on the 1st Nov.
I was talking to Allan from Avon engineering supplies today, ( he supplies a lot of our equipment at work) I asked him about teflon string that was being discussed in another thread. He said it is available here but couldn’t say where, just that he had seen it recently.
I also got an email from Kevin who lives in pegasus village asking me about supplies of materials. He is from the UK and said he is very restricted for supplies here. I told him about the Little Metals Co.
I suppose you saw my new engine in its rough form at the moment. I want to use the same self pressurising pump that Phillips used in the 1930s engine which will be driven off the opposite side of the piston to the crank; a bit hard to describe here but when I see you I will explain how I think it will work As you see I have used a crank, bearings and conrod from a line trimmer which should handle more power than the links and pins I have used so far; the engineering has already been done. I am going to use two gas seals inside the bearing set to minimise losses. The only thing I am concerned about is the extra friction from the seals might make starting more difficult. The stroke is 33mm and bore is 37mm.
mark
PS When I said Warblington in an earlier post I meant Warbrook. Combination (ala James Joyce} of Warbrook and Darlington
Edited By Mark Smith 3 on 29/09/2009 09:23:09
