Hi Mark, went and tried the Phillips expirement, 45min took the temp down to -7.1deg C, but thats not enough to run the motor although there was indication that there was something there, it would need to go quite a bit colder than that(might need an electric motor), I think -20 would be a target I could try for. On reversing the drive on the slave motor it took about 10 min to get to 40 deg C,it wouldn’t go any higher. I then ran the motor I’d been using as a driver without a load, the max speed I can easily read on my taco is 1500rpm,it was well over 2000rpm, and maybe nearer 3000rpm, and the peak rpm was a miniute after turning the gas off. The displacer started to vibrate, touching the cylinder sides, I don’t think it did any damage but it did scare me a bit, its never gone that fast before(the one in James G. Rizzo’s book did 320rpm). Ian S C
