Hi Wolfie,
The problem is that there are different alloys within each type of material and this composition decides the particular properties of the material depending on what it is to be used for.
First it is necessary to understand what each property is. For example ‘Malleability’ means that a material can be hammered into shape The particular type of mild steel used for car bodies has to be malleable in order that it is shaped easily into complex shapes but retains it’s strength (the presses used to shape panels are after all just great big hammers). Copper is also malleable but it has other properties which make it unsuitable for this purpose. Some mild steels are used for machined components, malleability is not so important here but the ability to machine well and leave a good finish is, so elements are added to give it good machining properties, and so on and so on.
Another property is ‘ductility’ this means a material can be drawn out into a wire, obviously copper is very ductile hence it can be used to make wire, it also has good conductivity so is used for electrical cable. Some mild steels have good ductility and can be drawn into wire form and used to make cables, some higher carbon steels have these properties but are stronger and make high tensile cables. Lead is malleable but not ductile, Some brasses are hard and lack ductility and are great for engraving, some have good bearing properties (but not as good as bronze) some machine well. Brass also resists corrosion and is attractive to look at and takes a good polish.
Tools need to be hard but usually tough (glass is hard, Curly Wurly is tough), Mild steel cannot be made hard but if we add carbon to the alloy (and other elements to produce say silver steel or HSS) it can be hardened by heat then cooling quickly and then toughened by tempering that hardness. How much you temper it depends on the application.
What I’m really saying Wolfie is that the material has to fit the job it is to do. It is the application that chooses the material not the other way round. and there are so many materials one can only give general guidance. If you are making a beam, it will be in tension, cast iron is poor in tension and good in compression, but mild steel is good in tension so that is the material (brass would be too expensive and lack strength to resist bending). If on the other hand you are making a support column than cast iron could be used. If you are making a plain bearing journal than Bronze is probably best, but mild steel is unsuitable.
This is not knowledge you can pick up easily in a short time except for a cursory overview. you need to look at the plans, see what is recommended and try to understand what properties are needed in that application You need to study plans and articles in Model Engineer and other magazines and books, see what others have written and read more widely. Local libraries usually have good engineering sections and can get books on loan about model engineering and techniques. The Workshop Practice series has good references and is cheap on Amazon. Build models by all means if you are impatient to get on but follow the plans even if you don’t understand why at first. For in depth knowledge there is no real alternative but study and asking others, both are necessary but be specific when asking.
Best regards and good luck
Terry
Edited By Terryd on 11/12/2010 12:46:21
