Horse Rasp on Aluminium
Home Forums Beginners questions Horse Rasp on Aluminium
  • #485776
    Chris TickTock
      @christicktock
      Hi Guys,
      On the web I have found sites stating a horse rasp can be used for aluminium for really rough smoothing out. Is this the case and does anyone do so and if so do they recommend chalk, WD40, paraffin or anything else to stop the teeth clogging.
      Chris
      Chris TickTock
        @christicktock
        #485781
          Perhaps you could do a comparative test, Chris
          … and share your findings for our benefit
          Brian Rutter
            @brianrutter93961
            Why a horse rasp? – A woodworking rasp is a quarter of the price,
            I have been using the same ones for five years on aluminium and they have never clogged.
            Toodlepip
            #485816
            Lee Rogers
              @leerogers95060
              I think what you need is a millenicut file . It will remove metal fast but will also produce very fine finish on the edges of sheet metal esp aluminium. I can remember my father using one on aircraft skins.
              #485835
              Chris TickTock
                @christicktock
                Posted by Lee Rogers on 15/07/2020 15:39:26:
                Thanks Lee (and everyone) yes it looks like a millenicut file is the tool required. One ordered thanks guys. Note they are advertised as not clogging so that answers that question as well.
                #485843
                Brian H
                  @brianh50089
                  Much used in the aircraft industry. Be sure to wear some stout gloves if not used to these things. Fresh out of college and in my first job, I came home in the evening with a series of semi-circular cuts on the palm of my left hand.
                  #485846
                  Chris TickTock
                    @christicktock
                    Posted by Brian H on 15/07/2020 16:57:06:
                    noted Brian thanks
                    #486340
                    Ian P
                      @ianp
                      Posted by Chris TickTock on 15/07/2020 13:27:31:
                      Hi Guys,
                      Chris
                      Chris, You said you found some information on a website so whilst I am probably a bit late mentioning this to you but shock-horror, not everything you read on the internet true!
                      Sorry if its come as a surprise to you.devil
                      Ian P
                      Edited By Ian P on 17/07/2020 21:14:11
                      #486347
                      Bill Pudney
                        @billpudney37759
                        Yep Millenicut files are the ones you want. I have a selection from my apprenticeship in the 60s. With careful use and storage they are still good. They will clog but the al.alloy needs to be the soft sticky kind, rather than the harder tempers, and yes beware of the left hand pain, we used to wrap the last couple of inches with masking tape, but probably a stout glove is better.
                        best of luck!!
                        cheers
                        Bill
                        #486355
                        JohnF
                          @johnf59703
                          Dreadnought or Millenicut, have never used a horse rasp but I think the tooth form would not work well ? Dreadnought are capable of removing material very efficiently, Millenicut give a finer finish.
                          Regards John
