Horizontal hit and miss engine
Home Forums Work In Progress and completed items Horizontal hit and miss engine
  • #498048
    Andy_G
      @andy_g
      I asked a question about cylinder oilers on here a few days ago that JasonB was good enough to answer.
      Here's the engine that I've been working on. It is my own design, and scratch built from bar stock using my 7 x 14 Chinese lathe.
      Thank you.
      Edited By Andy Gray 3 on 26/09/2020 22:08:01
      Andy_G
        @andy_g
        #498050
        Emgee
          @emgee
          Hi Andy
          That looks good and runs exceptionally well, is it just on fuel vapour ?
          Emgee
          #498053
          Henry Brown
            @henrybrown95529
            Very nice Andy, well done!
            Did you make the fuel tank? I have a similar task imminent and would be obliged for any tips.
            #498055
            Andy_G
              @andy_g
              Posted by Emgee on 26/09/2020 22:12:31:
              Thank you! smiley
              It has a fixed choke carburettor (fuel mixer?)  with a simple spray bar and needle valve that draws liquid fuel (Coleman fuel) from the tank.
              Fuel mixer
              Edited By Andy Gray 3 on 26/09/2020 23:19:27
              #498059
              Andy_G
                @andy_g
                Posted by Henry Brown on 26/09/2020 22:48:17:
                Thank you also! smiley
                The tank body is chromed brass bathroom waste pipe. (I had an off-cut).
                I wanted a brass bodied tank, but the price of brass tube seemed horrific – more expensive than solid bar of the same size. I tried all sorts to strip the chrome off the bit of pipe I had and failed, so ended up just using it as it was – it turned out OK!
                The ends of the tank were cut out of ~2.5mm brass sheet and both faces of each end were turned. prior to assembly, using superglue to hold them to a piece of faced-off aluminium bar in the manner of the Clickspring Youtube channel:
                • Centre punch brass sheet, scribe circle, saw roughly to size, then glue to the 'face plate' using a centre in the tail stock to locate the punch mark on centre,
                • Turn the OD and face off to leave a small pip in the centre. Machine a small shoulder to fit inside the tube.
                • Remove from faceplate and glue the opposite face using the pip to centre in a suitable hole in the 'faceplate'
                • Face off and round corners.
                • Remove from face plate. The pips stay on the inside faces (but nobody can see them wink)
                These were a nice, tight fit in the tube, and I just soft soldered them on (one at a time) by laying a ring of 0.5mm multi-core solder inside the tank and gently heating until it flowed into the joint, The second end had to be done 'blind', but it worked OK. (The bosses for the filler and fuel off-take fit through holes drilled in the tube and were soldered on from the inside with plumbers solder before fitting the ends.
                I hope that makes some sense!
                Another edit for a photo:
                Edited By Andy Gray 3 on 26/09/2020 23:41:26
                Edited By Andy Gray 3 on 26/09/2020 23:45:01
                Edited By Andy Gray 3 on 26/09/2020 23:48:48
                #498070
                  Now that is a good runner and looker too, usually I'm not keen on the barstock and cap screw look but you have executed it very nicely particularly with those recessed heads..
                  I also like the easy way that the lever over rides the governor latch while the engine is running.
                  #498074
                  Brian Baker 2
                    @brianbaker2
                    Very good Andy, could that be written up, with drawings, for publication in Model Engineer?
                    #498078
                    Henry Brown
                      @henrybrown95529
                      Thanks for such a detailed description about the fuel tank Andy, I'll be using a similar method! I plan to roll a sheet of brass to make the tube and then solder the ends in. Still not sure how to make the log joint between the ends yet so a bit of experimentation before I start I guess.
                      I just re-watched the video and it really is a credit to you, you must be very pleased with the end result…
                      #498088
                      Baz
                        @baz89810
                        +1 for seeing it written up in Model Engineer, I am sure quite a few people would like to make one, a very nice looking engine, well done Andy.
                        #498115
                        Andy_G
                          @andy_g
                          Thank you all very much! smiley
                          I'm not sure what would be involved in writing it up – I have (rudimentary) drawings for ~90% of it, but didn't take many photos during the build.
                          (I hesitate to confess that I haven't looked at the Model Engineering magazine since my father dabbled in model engineering in the early 1980s – there were plans for a shuttle valve engine from a small traction engine that my father and I started building at night school.)
                          #498118
                          Ron Laden
                            @ronladen17547
                            Excellent and such a sweet runner, it also speaks volumes for what can be achieved on a Chinese Mlini Lathe.
                            Great stuff.
                            Ron
                            #498139
                            Jim Nic
                              @jimnic
                              That's really nice, well done.
                              Jim
                              #498219
                              Andy_G
                                @andy_g
                                Thank you! smiley
                                #498221
                                Mike Poole
                                  @mikepoole82104
                                  A very attractive engine, not everything needs to look as though it was built by the Victorians. I like it.
                                  #507459
                                  Simon Birt
                                    @simonbirt51617
                                    Very nice and runs well. What have you used for the ignition? I am building a Farmboy and am starting to think about making sparks.
                                    Simon
                                    #507517
                                    Andy_G
                                      @andy_g
                                      Posted by Simon Birt on 14/11/2020 15:31:16:
                                      Simon
                                      Thank you
                                      I used a "Replacement Complete Ignition Set for Single Cylinder Gas Engines" module from Hobby King:
                                      https://hobbyking.com/en_us/replacement-complete-ignition-set-for-single-cylinder-gas-engines.html
                                      Unfortunately seems to be on back-order now
                                      It needed some careful shaving down in order to hide it inside the engine pedestal.
                                      Edited By Andy Gray 3 on 14/11/2020 18:47:18
                                      #507667
                                      PatJ
                                        @patj87806
                                        That is a nice looking engine.
                                        And runs very well too !
                                        Well done.
                                        #507731
                                        Andy_G
                                          @andy_g
                                          Thank you!
