Horizontal boiler
Horizontal boiler
Home Forums Beginners questions Horizontal boiler
  • #621696
    File Handle
      @filehandle
      Recently I saw 2 horizontal boilers in an antique centre. Approx 3 x 6". They are mounted on a thin sheet rectangle with a "fire hole". Top of boiler has wooden cladding. I presume that they are designed for a meths or gas boiler. Several bushes are fitted, one of the boilers has a pressure gauge and water level indicator. I assume that they are a part completed project. Priced at £75 each – would this seem a reasonable price? (I know not an easy question to answer unseen)
      There are a few (5 from memory) vertical tubes running up into the boiler. Am I correct in assuming that these direct hot air up into the boiler and will pass out through the chimney? This was the bit I was curious about – is this a standard design? Next time I am their, will will look more closely. Details may not be exactly correct as I am relying on my memory from a quick look.
      Thanks
      Keith
      File Handle
        @filehandle
        Second hand ones I have seen-queries
        #621722
        Nigel Graham 2
          @nigelgraham2
          That would be a most unusual arrangement, vertical fire-tubes in a horizontal boiler. They'd need a smokebox along the the top of the shell; perhaps with the chimney in the centre, but from what you say this is not the case here.
          Are they actually fire-tubes, or in fact a form of thermic syphon, so full of water in use? That is quite common on small horizontal boilers made for gas or liquid-fuel, with the burner heating the entire length of the shell.
          As for value… I could not say but it would depend heavily on their condition, and evident signs of good workmanship would be a start.
          It'd be worth asking if the shop also has any model engines etc, that look as if intended to accompany these boilers; or at least came from the same seller..
          #621742
          Paul Lousick
            @paullousick59116
            From the description, it is one design that I have never seen.
            Once again a photo is worth a 1000 words in describing it for a sensible answer.
            #621749
            Hopper
              @hopper
              Sounds more like water tubes sticking out he bottom of the drum. Google Stuart 500 Model Boiler and have a look at a few examples showing the water tubes.
              #621754
              nigel jones 5
                @nigeljones5
                these used to be common in the boating world. They are designed for short duration-high output used in straight running steam boats.
                #622100
                File Handle
                  @filehandle
                  Did get a second quick look today. Does look like a marine boiler that I found online.
                  For example **LINK**
                  Vertical fire tubes go into a rectangular smoke box and chimney (both missing on one).
                  Thanks for all of the comments – this site always has helpful comments. Will try and have more time to speak to the staff next time.
