Posted by Frances IoM on 07/12/2015 18:51:49:
just appeared on another (non-ME) forum I lurk on –
http://lasergist.com/
would appear you can make your own + even etch it with your name
Just had a look at that site – and read the bit which says "Depending on your design, the engraving position will have a tolerance of +- 3mm." So probably not much use them making hook rules then.
Both the Kinex and the Axminster rules are quite different to the Starrett version, probably because they are aimed at cabinet making rather than metal machining.
Edited By Steve Pavey on 07/12/2015 21:34:10
