I had a job in inserting a steel sleeve (bush, hole 25 mm) into a nozzle head of an injection molding machine. My worker used a hard steel bush and finally when I mounted the contraption on a cnc mill and bored it , even after many adjusting of the boring tools, regrinding the carbide tool, I found the bore tapering down at the bottom. Finally I reduced the rpm to 120 and did a very low feed and managed to get the bottom almost parallel.
Now I needed to hone it. I turned out a wooden short pole 100 mm long, 23 mm dia, used a hack saw and split one end (made a slit) in the center to a distance of 50mm.
inserted a strip of water proof abrasive paper strip, 3 inch long 50 mm wide into the slit and wrapped clockwise looking from the slitted end. The other end of the wooden pole was turned to a dia of 15 mm so that end could be held in a chuck of a drill.
kerosene was used as the lubricant and after some time starting the drill, moving it up and down many times,, I got a perfectly honed polished surface. YOU CAN USE A PVC rigid water pipe slitted at one end and do this too provided the chuck end is made of a tight fitting plug of nylon, alu , brass, or steel plug with a reduced dia at the stem to fit into a chuck.
For big bores , I have use several 90% bends of PVC piping and straight pieces, glued to gather just like a honing tool with four limbs, slit the limbs in middle and inserted water proof abrasive paper with rubber pad glued to the limb.
the rubber pads helped in applying honing pressure . I turned the contraption with a drill, reduced speed, using kerosene as lubricant.
I have honed 12 inch, 15 inch old Ruston Engine sleeves with this. Hope some on can pick up this to do some interesting work. With love from Sri Lanka.
