I had hoped by now to have been well into another pair of scaled up diesel engines but thanks to a timely visit from fellow forum member Bill Starling I have recently been well and truly ‘side tracked’ into tackling something I have been putting off for far too long.
In 1992! so my notes say I began a Bentley BR2 rotary engine. I knew nothing about petrol engines – still don’t – but did fancy it as a ‘machining project’ Intermittent work on it until 1996 saw all the major components made with the cylinder heads rough turned with the lower faces, combustion chambers and valve boxes finished. I packed it away for some reason with the quip in my notes “back soon”
Here we are fourteen years later and Bill’s visit provided the impetus to do something.
I made several cutters to finish these heads off and thought that this might be of interest to those who as yet have to travel that path. It’s not difficult and gives another dimension to your machining capabilities.
Left to right these are a 15mm x 40tpi LH tap. Not tempered it cut much better than anticipated, Next the counterbore for the valve boxes. Slow work due to having to clear the swarf from the flutes. It cut eighteen boxes and nine cages without resharpening though. The three spotfacers worked well too the right hand two are not tempered. All these and those in the next pic were made from silver steel and quenched in oil.
This image shows the failures too! From the left the first did two fins in the set up piece before shattering. As I changed it out I noticed I had not locked the head on the mill
. The second due to insufficient backing off became crowded and broke on the second fin on the first head. (Raise of eyebrows!) The third however cut all the side fins (one side on each head at a time) losing first one tooth at some stage, working well for some time with two before losing another finally flycutting with just one tooth until three fins left to do – sterling service I’m sure you’d agree. The fourth had little work to do then and the last cutter was made longer in order to clear the fixture when cutting the top fins.
It was noticed that the crowding was exacerbated when using coolant – I can only brush it on – this seemd to make the swarf stick in the slots. The top fins were done without using any at the same speed – no sticky moments and the cutter did the lot without re-sharpening.
Incidentally I have some pics showing the hand cut backing off and sharpening carried out if it will be of help to anyone.
It was neccesary to modify some standard cutters too!
The slot drill has a 4 degree taper ground on the bottom for cutting the tops of the fins. The next was a short boring bar made from an FC3 cutter for recessing the exhaust cages and the last two were ground away FC3 cutters for cutting the recesses in the bolting pads and the corners under the inlet valve face. All werer ground on the off hand grinder and cut well – but all were tested first
The parts all began like this
And finally finished yesterday like this
This shows a couple of the exhaust cages and the rather fiddly cylinder head nuts
So thanks to Bill I have made a major step forward on this project. It is going ba
