Home made screws
Home made screws
Home Forums Work In Progress and completed items Home made screws
  • #537495
    Steve Crow
      @stevecrow46066
      I got a few samples of M1.2 screws for a project and wasn't happy with the quality or material so I decided to make my own. I would have to turn down the head and shorten commercial screws anyway.
      It went a lot quicker than I thought. Once I had worked out a "mass production" method I made around 40 ( I need 80+) before running out of silver steel. That took about 6 hours workshop (kitchen table) time.
      Here is one on a penny.
      This is unfinished – it still needs chamfering, polishing and blueing.
      I'm quite happy with the result.
      Steve
      Edited By Steve Crow on 01/04/2021 16:10:05
      Steve Crow
        @stevecrow46066
        #537497
          Great stuff, Steve yes
          Nice to see some small scale machining.
          Jon Lawes
            @jonlawes51698
            Looks great Steve, nicely made.
            #537501
            Steviegtr
              @steviegtr
              Wow that is what i call a dinky screw. Nice work.
              Steve.
              #537503
              Ian Parkin
                @ianparkin39383
                Can you talk us through your mass production process and what tools fixtures you used?
                #537505
                Brian H
                  @brianh50089
                  Very nice work Steve. It's not too bad if you can get a rhythm going.
                  #537511
                  Steve Crow
                    @stevecrow46066
                    Posted by Ian Parkin on 01/04/2021 16:48:56:
                    Hi Ian, I can try.
                    First of all, I used a Sherline lathe and milling machine to make them from 1/16" silver steel.
                    I did it in three stages.
                    First I fixed a turning tool (I used 0.2 radius "ali" type inserts) and a rear mounted parting tool to the lathe carriage about 20mm apart to leave room for the threading.
                    The material is held in a watchmakers collet and turned to desired diameter and length. Set Y dial to zero for future turning.
                    Use jewellers cup burr in pin vice to lightly chamfer.
                    Bring forward the tailstock with thread rolling die/head attached and form the thread. (I bought a Russian made M1.2 thread roller on ebay for £13.01 inc. postage from St. Petersberg. Fantastic value for money.)
                    Repeat with the cup burr.
                    Bring in the rear parting tool, index from the screw shoulder and part off.
                    Withdraw some more rod from the collet and start again.
                    For the subsequent screws, your Y Is already indexed to zero and you can do it in one cut.
                    The next stage is just facing the heads after parting. Again you can just set your X and do them all in one cut.
                    The third bit is the slotting.
                    I used a homemade square collet block held in a mill vice and a 0.3mm slitting saw.
                    I hope this is helpful. If you want more clarification, just ask.
                    Steve
                    #537514
                    Mick B1
                      @mickb1
                      The screw's something I could've done, though with some difficulty and maybe not as neatly.
                      It's some of the other stuff in your photo albums that's really remarkable – congratulations on your work!
                      #537516
                      Brian H
                        @brianh50089
                        Steve, for slotting, do you hold by the thread or do you have a threaded collet?
                        Edited By Brian H on 01/04/2021 18:07:39
                        #537523
                        Phil P
                          @philp
                          Steve
                          I have just been experimenting with those thread rolling dies with very little success.
                          I have 1.2 1.4 and 1.6 sizes, I tried the 1.6 first and it just necks the raw material off and the roller box has to be dismantled to remove the broken end, mine was mild steel not silver steel though.
                          Do you know if the three "rollers are meant to revolve or do they just form a thread as they push forward, mine do not revolve and the friction is just too great for the material to hold up against the twisting force.
                          I am making longer studs rather than headed screws.
                          Any advice would be welcome.
                          Phil
                          #537530
                          Ian Parkin
                            @ianparkin39383
                            Steve I’m in awe at all that on 1/16” ss
                            #537561
                            Steve Crow
                              @stevecrow46066
                              Posted by Brian H on 01/04/2021 18:07:23:
                              Hi Brian, I just use a 1.2mm collet clamped on the thread.
                              Steve
                              #537604
                              Steve Crow
                                @stevecrow46066
                                Phil
                                Hi Phil, maybe the problem lies in the diameter of the blank you are threading.
                                The theoretical diameter for thread rolling is the pitch diameter of the thread. This makes sense if you think about it as the tool deforms equal amounts of material in and out.
                                Pitch diameters :- M1.2 =1.038, M1.4 =1.205 and M1.6 =1.373.
                                In practice the blank should be slightly less. I've only tried the M1.2 die and I turned down the screws to 1.02mm. It works fine on 1mm rod as well.
                                For M1.6, I'd give 1.35mm a try.
                                The rollers don't revolve. The alignment of the wheels forms the thread. Did you get a little threaded rod with each tool? When assembling the tool after a breakage, this is used to ensure the rollers are in the correct alignment when tightening everything up. If you can screw this in and out easily, everything is in the right place.
                                I hope this is helpful, let me know how you get on.
                                Steve
                                #537609
                                ega
                                  @ega
                                  Posted by Steve Crow on 01/04/2021 17:52:54:
                                  I couldn't immediately find your "thread roller" but did see a Cyclo item at nearly £100 and that without rollers; I have put mine in the safe!
                                  I make the penny 0.8" in diameter ie not metric?
                                  #537613
                                    Posted by ega on 02/04/2021 10:23:10:
                                    Then yours may be slightly oversize
                                    They apparently make them 20.3mm maximum devil
                                    [ no reference temperature stated though ]
                                    https://en.wikipedia.org/wiki/Coins_of_the_pound_sterling#Dimensions
                                    ega
                                      @ega
                                      MichaelG:
                                      Thank you. I'll measure again with greater care!
                                      In accepting the imperial measure I may have been influenced by the understanding that one of the pre-decimalisation coins was exactly 1" in diameter.
                                      #537622
                                      Phil P
                                        @philp
                                        Posted by Steve Crow on 02/04/2021 10:06:13:
                                        Phil
                                        Steve
                                        Hi Steve
                                        Yes I did get the test piece with each one, and it does screw in easily, I actually measured the remaining bit of plain section on it to find the blank diameter and it seemed to be 1.4 mm so that is what I tested it at.
                                        I will have another play and see if 1.35 mm works out any better, I could not see how it would work with the rollers revolving as they are not retained on the shafts, so it has to be down to the blank diameter I suppose.
                                        Do you use any lubricant on it when forming the thread ?
                                        Phil
                                        PS, Just so others know what we are on about, here is a link to one.
                                        Thread-Rolling-Head-Die-M-1-6×0-35 202976842528
                                        Edited By Phil P on 02/04/2021 12:19:32
                                        #537629
                                        Steve Crow
                                          @stevecrow46066
                                          Hi Phil
                                          I think that extra couple of thou is critical. If the blank is only slightly larger than the pitch diameter, there is too much metal and nowhere for it to go so it jams and breaks.
                                          It's a bit like tapping a slightly undersized hole – the tap's going to break.
                                          I'm sure that you could go down a bit less than 1.35 mm for safety.
                                          I've done all my threading dry so far. My thinking was that I'm not actually doing any cutting so there is no advantage. I might be wrong on this.
                                          Steve
                                          #537696
                                          Phil P
                                            @philp
                                            Hi Steve
                                            You were correct, the blank size was the problem.
                                            I made a fresh attempt using 0.053" (1.35mm) as you suggested and it worked a treat even on a long thread.
                                            It also gave me a chance to try out the ultra slow speed inverter setting I rigged up on my Pultra 1770, I can run a thread up to a shoulder under power and then reverse it off again, I am really pleased with the results.
                                            I just need to set up the capstan attachment now and go into mass production, but that is another story.
                                            Thanks for giving me the advice to carry on, I had all but given up on the roller box but it works very well.
                                            Phil
                                            #537785
                                            Steve Crow
                                              @stevecrow46066
                                              Hi Phil
                                              Glad it worked for you. Are you using mild steel?
                                              It makes threading a joy. I wouldn't have contemplated making all those screws using any other method.
                                              Also, if you inspect the thread under magnification, the finish is so much better than a cut thread. there is no tearing and the surface has been burnished by the rollers. It's stronger too as the "grain" of the metal has been "folded" rather than cut. I believe it work hardens the material as well.
                                              I also threaded my screws under power even though they are only 2.5mm long. I have to reverse off manually though.
                                              These Russian tools are great value. I've got a few sets of involute gear cutter from the same supplier. I might do a post about them at some stage.
                                              Nice lathe you have there, by the way.
                                              Steve
                                              #537808
                                              ega
                                                @ega
                                                Phil P:
                                                Thank for posting the link!
                                                #539263
                                                Model Enginerd
                                                  @modelenginerd
                                                  Nice. I made mine on the kitchen island as well with my Sherline (wife is a keeper).
                                                  I ran 3/16" Hex stock from hobbymodelkits.com (nice if you need small quantities in US).
                                                  Sherline's 2 sided tool holder can hold the HSS to turn the major Ø and the 60 degree to run the threads on the other. I have the backside parting tool setup opposite side for the final op, so no tool changes. I did flip the bolts to knock the edge off the heads.
                                                  I have the threading attachment installed inverse and with an extension, so the motor can turn on anytime. After I'm done I decouple the drive gear. I leave the threads at 40 tpi since just about everything I do is around that pitch.
                                                  The nearest spacer in the photo is a bit off axis because of a floating fit (looks ugly in the photo), but you get the idea.
                                                  #539456
                                                  Blue Heeler
                                                    @blueheeler
                                                    Great job on those small screws.
