I'm a bit late to this party but I am a Wabeco mill owner, at least!
Some time back I was playing with the idea of a CNC conversion for my Warco VMC, going for ballscrews and all, but was still worrying about how all the bits would fit without stripping it first, given various comments on various forums about maybe having to machine clearances under the table.
My wife persuaded me to take one last look at eBay for something second-hand and. lo and behold, a Wabeco turned up for sale – fresh on the market and only about 25miles away. Turned out to be a 1410LF hs. Can't quite remember the difference between the 1210 and 1410, but the LF and the hs are significant. LF means Hiwin profile rails instead of dovetail slides, and hs means the high-speed 2KW 7500RPM spindle. I think these are standard Wabeco upgrades, but this machine had had been upgraded by a US outfit and had ballscrews, driven by servos not steppers. In place of the standard (and not very highly regarded standard Wabeco software) it used Mach3 and an Ethernet SmoothStepper. The spindle was also BT30, not MT2, and it came with the full enclosure and stand, plus coolant system. In all, a pretty good bundle. I'm not sure if the standard machines have a counter-balanced head, but this one does.
I doubt if you will find another same-spec machine in the UK, but in terms of structure and build it is still Wabeco. It is not as stiff as the Warco – there is just not as much iron in it. The swivelling head has swivelled by itself once due to me trying to take too heavy a cut by accident as the clamping arrangement is not that great. However, within its capacity I have found it to be an excellent machine, even down to a recent experiment machining a HSS form tool using a carbide cutter. I have used cutters down to 1mm in steel where the high speed is really useful – it does 140-7500RPM without belt change. The axis handwheels all have fold-out handles for manual operation but because there are no table locks and the ballscrews move very easily, this is not a great idea. However, using a wireless MPG and keeping it under CNC control works well for me.
I did replace the Ethernet Smooth Stepper with a UC300ETH and UCCNC software, partly to get rid of Mach3, partly because I was having random comms issues with lost connections from time to time, and I decided to make them all go away by replacing the obsolete hardware and software with something current and supported. Pretty easy job to do, by the way.
Not sure that I have answered many of your questions but happy to help if I can.
