Not an expert at all in casting – merely an observer on the Defence QA side. Armour castings, engine blocks, and one or two other funny things in funny materials.Some of the larger single crystal stuff and some of the exotics being cast under argon.
I should apologise if I used the term “dry” loosely – I am familiar with mould construction. I was really referring to “liquid” or “spare” water. which can also lead to hydrogen embrittlement in those materials prone to it.
Could I reword that to say that ones process control in making a mould needs to be up to speed with respect to both design and material content, or the pouring process can be frustrating at best, and very interesting at worst?
As an aside, but it does show what a bit of water can do. We had an embrittlement problem in ferrous armour welds. No one could track down the problem source. In the end it truned out that they were using the rod drying oven to heat their pies, which gave off steam which got into the rod coating, and since welding is a casting process……. Water control is quite important in castings, even as vapour in small quantities, which is why the MOD specs controlled the amount of water to be used in moulds very closely indeed.
Edited By meyrick griffith-jones on 30/08/2009 23:40:43
Edited By meyrick griffith-jones on 30/08/2009 23:47:40
