Hole tolerance help needed.
Home Forums Workshop Techniques Hole tolerance help needed.
  • #16072
    Brian Abbott
      @brianabbott67793
      Brian Abbott
        @brianabbott67793
        Hello all, can you offer me some advice.
        If i have a diameter 63mm with a h6 tolerance. (Guide bush)
        What tolerance should i apply to the bored hole to ensure a good slide fit ?
        I have never been any good with tolerances, normally i just machine to fit but on this occasion i am having the holes bored by a contract machining firm in spain and want to make sure i give them the correct tolerance.
        Thanks for any help.
        #401306
        Jeff Dayman
          @jeffdayman43397
          Is it sixty three mm or six point three mm with h6? Just want to be sure before looking it up.
          #401308
          Brian Abbott
            @brianabbott67793
            Hello.
            yes, 63mm not 6.3mm
            Thanks
            #401309
            Phil P
              @philp
              Depends what you are aiming for but H7 would be a good starting point imho.
              Phil
              #401311
              Jeff Dayman
                @jeffdayman43397
                G7 / h6 will give a sliding fit (clearance, but not free running)
                According to the chart I use:
                G7 for 63 dia hole has tolerance +0.04 / +0.01. Limits 63.040 / 63.01
                h6 for 63 dia shaft has tolerance +0.00 / -0.019. Limits 63.000 / 62.981
                If you need a close running fit F8 / h7 might be a better choice
                #401312
                Brian Abbott
                  @brianabbott67793
                  Thanks Phil, Thanks Jeff.
                  I have just been through the suppliers info and i think i have wasted your time, sorry.
                  Bush size is 65mm +0.019 + 0.030,
                  Hole size should be 65mm +0.00 + 0.019 (H6)
                  Thanks for your time both.
                  #401351
                  mechman48
                    @mechman48
                    Hi Brian
                    Get yourself a 'ZEUS' book; it has the charts for ISO fit BS 4500- 1969 for clearance, transition & interference fits, plus a lot of other useful information.
                    George.
