Afraid I don't understand what all this c—p has been about,nor why we need another marathon series on short lengths.. For 99% of us who are happy just to get the job done the solution is pretty obvious ,ERs, and if some lucky model engineer has a machine that is powerful enough that these give problems then reduce the cut,or is this too easy ? Judging by the "Guhring " video any cut classed as just short of "Brutal" should not be a problem.
For the small number who are reading a model engineering site but are involved in production then reducing the cut may be less welcome and increase machining time and cost. However if they can't analyse their problem and come up with an alternative method of work/tool holding they should n't be in the business of producing metal parts,and probably won't be for long. So who has a problem ? No one, except production machinists who should know enough to solve their own problem . In other words no one has a problem. Model engineers can't produce the problem and those who can should know the answer.
i do find it instructive that Mr. Stevenson has typically ,IMO, offered to come up with, and will no doubt do so, a solution to the problem for the amateurs who are determined to spend their time machining short lengths but refuse to adopt the recognised and simple solution.
JS,I know, has his own Swinglite (and is no doubt a black belt in its use ) and does n't need me to defend him. However it is probably easier for me to say that in my opinion he is far from an ordinary machinist in that his bodges are actually far from bodges and demonstrate good lateral thinking in solving engineering problems that benefit and amuse us all. Also I have for one gained great benefit from his willingness to take the trouble to write up and publish articles on solving model engineers problems e.g. taper turning using a boring head, making gear cutters etc etc. When you add to this the extraordinary efficiency and effort he put into taking up the Chris Heapy site and ensuring its survival, the improvements he has instigated in simple accessories at Arc, and his work at exhibitions sharpening for a charity fee and not least the improvement in the general tenor of the posts on this forum since he became a moderator I can think of few others who do more for model engineering. I speak as one who's efforts in eliminating rivet poverty in the UK failed to be recognised by the Palace.
I could add more but will limit his embarassment. I felt compelled to add this paragraph in view of some extraordinary posts submitted recently. Not that JS is above criticism . I have in the past taken serious issue with him when certain items have been rapidly sold on another website he has connections with ,without his checking with me first as to whether I required the said items . I'm never more than a phone call away. I also never proved anything but there was a time long ago when QCTPs hardly ever appeared on the aforementioned website and I often wondered whether he was trying to corner the market in QCTPs and holders in order to hold us all to ransom. I believe he has more than a few.
Alan Frost (brown belt , pink Swinglite,green engineer)
Edited By alan frost on 27/09/2016 15:15:25
