Weldon shank end mill holders.
Ok – not that it matters much to us, but for precision machining, OR for long production runs:
1) There is play in a Weldon-shank end mill holder. (there HAS to be, otherwise one can not put the end mill in!) This means that, by definition, the end mill is not centered, thus will wobble;
2) Long production runs, the end mill flexes around the juncture of the set screw, leading to wear on the collet. And, when they start to wear, the wear increases quickly, and the end mill is not held securely.
At least ER collets will hold end mills securely for the length of the collet-endmill interface, and the end mill is at least close to centered…
Food for thought;
John.
