Hopefully, you’ll be able to repair your existing motor. However, if it’s beyond repair, there’s a point you need to be aware of.
According to the motor plate on my BFE65 (geared-head, MT1 spindle, c.1990 vintage), the motor has an IEC 63 frame which would normally correspond to a shaft diameter of 11mm. However, this motor actually has a shaft diameter of 14mm which corresponds to an IEC 71 frame. So, if it comes to replacement I suggest you:
1. Measure the diameter of your motor spindle,
2. Pay close attention to the specs of any new IEC 63 motor you select to ensure the spindle diameter matches your existing motor.
Joe
