Hobbymat BFE65 Milling machine
Home Forums General Questions Hobbymat BFE65 Milling machine
  • #635810
    paul mcquaid
      @paulmcquaid48093
      Hi.
      Can anyone out there tell me if there is a You tube video available or similar, on how to use a Hobby mat BFE65 Milling Machine? Or even a manual on setup as I can't work out how to stop the drill head from turning when I try to mill anything?
      I have tightened all the pinch bolts as tight as I dare without breaking them but it refuses to stop moving. On very light work I just try to hold the dam thing still with me pulling it back as I slowly try and cut something, Which isn't ideal.
      Any Info would be greatly appreciated.
      paul mcquaid
        @paulmcquaid48093
        #635834
        Roger Woollett
          @rogerwoollett53105
          I assume you have locked the head with the two handles at the back. You do not say how much the movement is but I have found that the head does move left/right under slight pressure. Although the column looks substantial I think it must be twisting. When milling I try to use the X (left/rigjt) movement rather than y (front/back).
          #635842
          Bizibilder
            @bizibilder
            Have you checked to make sure there is nothing in the slot preventing the pinch bolts from working? A bit of swarf or scrap of metal maybe? You may thing you have tightened it but maybe just trapping the foreign object?
            #635846
            Thor 🇳🇴
              @thor
              Hi Paul,
              Welcome to the forum, is this the manual you are looking for?
              Thor
              #635847
              Bazyle
                @bazyle
                This sounds like the problem on all round column mills. You have to take very light cuts or work at right angles to the bed.
                #635898
                Steven Corston
                  @stevencorston14096
                  There are three allen screws on the base at the bottom of the column. The top and the bottom ones are the clamping screws. Make sure that the centre screw is loose as its job is to open the slot and so limit the clamping force of the other two screws. I have removed the centre screw completely and have had no problem at all with the head moving in 40 ish years of use.
                  Hope this helps,
                  Steve
                  #635904
                  Ex contributor
                    @mgnbuk
                    Page 34 of the manual Thor linked to shows that there is a full length key mounted to the column that constrains the head casting, which has an "adjusting gib" and a "clamping gib". Difficult to see how the head could swivel on the column with that arrangement, so is the column rotating in the base due to inadequate clamping here ?
                    Nigel B.
                    #635905
                    Ex contributor
                      @mgnbuk
                      Nigel B.
                      #635909
                      DiogenesII
                        @diogenesii
                        Posted by Steven Corston on 03/03/2023 12:36:22:
                        Hope this helps,
                        Steve
                        This. absolutely.
                        You could try Lathes.co.uk for a manual, or there used to be a guy on Ebay who had some.
                        Edited By DiogenesII on 03/03/2023 13:12:43
                        #635967
                        DiogenesII
                          @diogenesii
                          I'm back from work.
                          The 'stand-alone' mill seems to be more often badged as a 'PRAZI' product, and was designated the BF400. It comprised the BFE65 Milling Head and column, mated to the KT160 x 450 Co-ordinate Table.
                          The cover of my copy is enscribed;
                          "PRAZI
                          BF400 – Mill Head
                          BF500 – Mill Head
                          KT450 – XY Table
                          Milling Machine"
                          It's probably most sensible if I PM you and tell you where I think I got it; the memory is a little treacherous and you'll have to send an enquiry, but at least you now know the name of the document you seek.
                          #636535
                          Michael West
                            @michaelwest55359
                            Paul, a good source of information on the Hobbymat lathe and mill is the group resource at
                            Prazi-Machining@groups.io
