Posted by James Mitchell 3 on 03/05/2022 23:35:56:
…any suggestions?
To make any sensible suggestions we need far more information. For starters:
What maximum size of workpiece do you want to cut?
What sort of machining – 2.5D, 3D or full 4-axis?
How much space is available?
Budget?
What sort of steel, ordinary mild steel, or tool steels and stainless steel?
I have a Tormach 1100 which will happily cut steel, like these brackets in hot rolled steel:
By hobby standards the Tormach is a fairly large machine at 450kg, and is the same horsepower as my Bridgeport. That not withstanding I find the Tormach works better running small cutters at high spindle speeds rather than running large cutters at slower speeds. A high maximum spindle speed is important, 5100rpm on the Tormach. Even that is a bit slow for really small cutters. I have added a high speed spindle for use with small cutters, like this 1mm ballnose cutter, running at 24000rpm:
