I recently fitted my Clarke CL300 lathe with a DRO kit from Arceurotrade.
For those unfamiliar with them, these readouts fit directly to the feedsrews of the top slide and cross slide so don’t measure actual movement of the axis, but as the provided screws are accurate, the system works well.
They only have 3 buttons, which are, On/Off, Zero and inch/mm and very little in the way of instructions on how to use them, but they do read to 0.001mm!
This could be another one of my “well that’s obvious” tips, but I messed about for a day or two and you never know who else is out there that can’t see the wood for the trees.
Anyway, to my tip:
Take a light cut along your workpiece and carefully measure the diameter. Move the carriage clear of the job and zero the cross slide DRO. Use the DRO to then wind the slide forward a distance equivalent to exactly half the distance you’ve just measured (the radius).
Press Zero again and you’re done!
All readings from now on will be of the radius of the part (ignore the minus sign), which I find much less confusing than zeroing at say 10mm diameter and having the readout display 1.375mm once I’ve reached 7.25mm diameter.
I find I’m using my vernier and micrometer much less after fitting this kit as it really is accurate – far better than I expected.
Martin.
