A few silly but useful tips:
Paint the workshop floor( with floorpaint of course). Makes things like little nuts/screws/washers/etc dropped on the floor much easier to find. Colour Red works for me. Plus block off under the benches etc as suggested earlier on this thread.
Philips or crosspoint screw heads always go ’round’ in the drivepoint and then the screwdriver just slips around as soon as the going gets tough when screwing them in. Take the screws out and hacksaw a slot across the drivepoint and then use a blade type screwdriver. It has so much more contact area in the slot created to turn the screw, always works for me to get the tricky screws in.
Seized up screws in wood to be removed? Hold a (hot) soldering iron tip on the screwhead for a few minutes, then try to tighten the screw a tad first before unscrewing, to ‘break the stick’, and it should then screw out.
Rubber hose won’t go on the tube? Heat for a few seconds by dunking the end in a mug of boiling water, or heat with HI’s (Her Indoors) hairdryer, and it will soften and zoom on.
And don’t forget HI’s washing up liquid, helps all sorts of sticking things to slide in easy when they refused to slide in before. Just remember to put the liquid back before she misses it, or buy your own.
Raid HI’s kit again for the talc (better still, get her buy you your own tub/tube for the workshop when she does the weekly shop – supermarkets own brand baby talc is ideal, you don’t need expensive poncy scented stuff) and use it to coat wires before pulling through conduit and they will wizz through. Talc is much underrated in the workshop, as is washing up liquid. Also use talc (if you don’t have french chalk) to coat rubber rings etc when they are just sitting on the spares shelf waiting to be used – helps protect them.
ChrisH
Edited By ChrisH on 15/10/2010 23:48:10
Edited By ChrisH on 15/10/2010 23:49:59
