Hi Niloch,
As you can see by the overwhelming number of posts, this idea is a non-starter. Such apathy is surely why our Editor has to virtually plead for material to publish.
Come on chaps and chapettes, if every one of you submitted just one hint or tip there would be a new ME special to publish.
Hint on four jaw work centring, if you are contemplating much truing, as surely you must if accuracy is your aim, make yourself a tool post mounted DTI holder. Despite what most of the books show, even from the most famous old timers, mount your DTI horizontally and on centre height, not vertically on the cross slide. The obvious benefit is that you have a very easy to use and precise rough set facility.
Put your work in a four jaw or grip-tru and you can bring the DTI into near contact and then spin the chuck, if it is still clear move the cross slide in till it touchs the point of the work that is nearest to it, then turn chuck again. If the the clearance is within the movement of the plunger, move the DTI in till you have used about half the plunger movement. You are now ready to start centring the work.
Rotate the chuck till the plunger is far in the DTI as it wants go whilst in alignment with one of the jaws, say this jaws is #1, slacken the jaw opposite (#3) and then tighten #1, Rotate chuck till another high point is shown on the DTI and repeat process, perhaps it is #4 this time, well slacken the opposite one (#2) and tighten #4. Repeat the process till you have about 2 thou of movement on the DTI when the chuck is turned. Now we come to the bit that seems to confuse beginners, I don’t know why but it does. Turn the chuck and move the cross slide till the average reading is zero, that means the hand moves an equal amount either side of zero, now the point of an average is that it is in the middle, so any movement towards it is getting nearer to centre, if you follow my drift. So now you turn the chuck till one of the jaws shows the highest reading and tighten that one, how hard you tighten it is a matter of judgement learnt from experience (although as a side note I once made a torque wrench type chuck key for this purpose, but we wont go in to that too deeply).
There is usually about half to one thou of “slop” in the jaw adjusters, so watch the dial and tighten till you get a reading of near or at zero. Turn the chuck till the next highest jaw is aligned and tighten that one to get at or near zero. Rotate the chuck a few times and see what happens, if there is a steady rise and fall of the DTI hand with each rotation, repeat the last process. If you can’t reasonably tighten the jaws any more , just slacken the opposite one a bit less than a tad, but a bit more than a gnat’s doings., and tighten the first one again. Don’t be surprized if things show more than one rise and fall with each rotation, even ground stock is not always round, although it is of one diameter (a consequence of centre less grinding, but that’s another story)
It is because of this not round round stock that you can only really check the run out at each of the four jaws, otherwise you will be chasing an accuracy that is unobtainable.
All of the above sounds long winded and difficult, it really isn’t and once you have done it a few times I assure you that you will be able to true up work in less than a minute, possibly even square stock, It is a skill that is better demonstrated than written about, but if you remember to only work on two opposite jaws at a time and aim to only tighten jaws not loosen, it will soon come to you.
On your Grip-tru if it has four adjusting screws then follow the above and it should work just as well.
Perhaps this should be a regular demo on the SMEE stand at MEXs, as part of their beginners training?
chris stephens
PS please remember if the above doesn’t make a lot of sense that Gibberish is my native tongue not English,
That’s my excuse, go find your own.
