Hi Alan and John
Appreciate your useful info. also the source of supply.
I was able to download the English version of Aciera F1 manual.
But I still puzzled how the spring drum and wire work?
Any diagram to refer to? Especially the way it’s tension? Why
the F1 mill table has to be at the lowest position not higher?
I stumbled across another similar principle, Record Morticer WRM 200.
It uses a compression spring and attached to a chain that winds round
a gear. So any downwards pressure (slot drilling) will be assisted by
upward movement after drilling…anyone knows about Record Morticer WRM 200??
Steve
