Following up on the original post re ASHP:
After many hours of research and trying to contact technical people I got nowhere further forward with this project. I feel that the UK renewables industry is overselling the capabilities of the performance of ASHP's in the UK environment. Not one company would get back to me with real-life performance data on UK installations.
I am now convinced that actual UK performance data is well below that quoted by the manufacturers – who all quote a DIN standard that tests the units in low humidity lab conditions. I believe that the constant icing up of the units, due to the high UK humidity, is what is causing the problems. The air temperatures that we experience in the UK are not the issue I think that as soon as the units form even a small layer of ice on the heat exchanger fins the COP falls off a cliff due to the inability to draw energy from the surrounding air. Ice has a low thermal conductivity??
Anyway, I shall continue to use my LPG boiler (we are out in the country so do not have easy access to natural gas). As it is we use such a small amount – less than 300kg/year.
In terms of the way forward on the climate I think the government should be funding carbon capture research and development. I do not see CO2 levels going down anytime soon and unless something is done to remove it from the air I feel the doom merchants may be right regarding our future. An interesting, although worrying thing is that in 1950 our co2 in air was about 300ppm it is now above 400ppm. According to research and ice core samples of air going back more than 800,000 years CO2 levels were always below this 300ppm level.
For info see: https://www.climate.gov/news-features/understanding-climate/climate-change-atmospheric-carbon-dioxide
There are many other independent reports supporting this level of CO2 increase.
Makes me think that capturing and reducing the CO2 in the air should be as high a priority as trying to reduce emissions.
