Firstly, many thanks to everyone who has contributed.
Martin, I think you have a good option with air to air. I thought of ducting warm air to rooms when I built – perhaps this would have been the best way?
Oily Rag, I have a friend who installed a GSHP, although he has had a few problems with it. 4.5m below ground, wow that’s deep! This is the first time I have heard of the ground freezing due to a GSHP, but I suppose logic would suggest it is possible if the energy coming up from the earth is not sufficient.
John, we also use a wood burner to heat up our thermal store which the UFH can draw from and we find this significantly reduces the amount of LPG we consume. I take your point about the COP when the outside temperature is below 0 deg. C – this is why I want to have an ASHP in parallel with the existing boiler. We are fully zoned by room using the UFH. Do you have any feel for what it does to the COP when the ASHP is in reverse flow due to ice build-up?
Robert, your system looks interesting – unfortunately, due to my heating design, I have to have an air to water system.
Martin. We are close to you (near Wellington) so, like you, we should not get long period of freezing weather. Our UFH is buried in 12T of screed which acts as a good thermal buffer so along with our high levels of thermal insulation (100mm in floor, 140mm in walls and 250mm in ceiling) should mean we only need to use an ASHP during the day when the outside temperatures tend to be higher.
Do you have a split system and do you heat your hot water as well from the ASHP? What outlet temperature do you run the ASHP at?
Andrew, bad luck with the oil pricing! I take it you have a mono system? What output temperature do you use? I do not have the facility to link the ASHP to the UFH without using the flow and return pipework from our LPG boiler via the thermal store – hence why I need a high-temperature ASHP which I believe has to then be a split system. I do not have any confidence in the sales pitches by the mono system manufacturers.
Neil, sounds interesting, are you using air to air split systems and whereabouts, are you?
Roger, have you installed the LG Mono system? I see it quotes 65 deg. C as a maximum outlet temperature. I have tried to get technical info from the LG site without success – I may not be looking hard enough. Generally, with mono systems the COP at this temperature is very poor – do you have any knowledge of the LG performance?
So once again thank you all for your comments, please keep them coming.
Steve
