Hi all, Clive I don't see where Phil says there is a crack ? Am i missing something?
Phil IMHO the plumbers flux should work well, I'm assuming it is same or similar to the product available in the UK for lead free plumbers solder, it is a white paste, this is an acidic self cleaning flux — I have researched this for a particular job I do and see no reason why it will not suit your application. Its not suitable for mine !
However assuming that what you describe is a thin wall pipe going into a female socket ** –same as a regular soldered plumbing fitting, I would do a test using a regular plumbing fitting and pipe say 10mm then cut the assembly longitudinally to see the result. Providing the solder has penetrated as required go ahead with your repair but you will need to separate the two components to ensure both are cleaned properly — self cleaning flux is not a get out of jail free card ! Proper preparation is still essential but ti will clean minor and I do mean minor oxidation but it will not clean the oxidation and or fouling I would envisage on your failed joint.
*** "The pipe is 3/16 thin walled copper and goes into a fitting "
Just my thoughts John
