@$$@$$1N63 (assassin) may or may not be caught by a crack attempt depending on the rules being applied, brute force will always break it eventually, just a matter of how long it takes.
Most password cracks will start with a decent dictionary, plus names of/from popular films, books, sports, pets, etc, then apply a number of rules to modify the letters: @ or 4 for A, $ or 5 for S, 3 or £ for E, 1 or ! for I, etc and then add numbers or random characters on the beginning or end.
I used to regularly run a similar crack against our password file, and used to break around 90% of them in under 10 minutes for the entire 1000+ entry file, and constantly warn them about weak passwords. Unfortunately several of them complained if their password ever changed from 'ChangeMe'!
You can still use the above approach, but don't use the same alteration for all instances of the same letter, and rather than use a single word, use multiple words or use a phrase that is easy to remember and choose the first letter of each word, that way it is not even in the dictionary to start with, you can also replace entire words with numbers 'won' or one' with 1, 'to' 'too' or 'two' with 2 and 'for' or 'four' with 4, etc.
C4t.$at.m@t – Cat sat mat
B6b$hy4w? – Baa baa black sheep, have you any wool?
Nitt4agm2c2taotp – Now is the time for all good men to come to the aid of the party.
The simplest way of obtaining any password is still watching someone type it in, so best to use both hands and learn to type it reasonably fast.
I used to have a passphrase for PGP (pretty good privacy ) around 20 years ago, that required a lengthy pass phrase. The one I used was my spellings for the Excalibur 'charm of making', that applied 2048 bit encrypyion to whatever message I was sending to someone:
Anaarl nathrak uthus bethud bethel nienthe – good luck to anyone remembering that whilst watching me type it in!
Watch out for criminals with cigar cutters looking to remove your thumb/finger (think Durant in Darkman ) for biometric recognition.
Edited By Zebethyal on 05/07/2018 14:36:40
