Hi, Toolmaker / CNC Programmer. Merseyside
Home Forums Introduce Yourself – New members start here! Hi, Toolmaker / CNC Programmer. Merseyside
  • #404754
    Karl Challis
      @karlchallis22968
      Hi All.
      My name is Karl, I'm 26 from Merseyside.
      Myself and my younger Brother 20 are apprentice trained toolmaker and CNC Programmers. We have a passion for old school machinery and techniques, and would love our own company at some point.
      We have just purchased, cleaned and restored a Marlow Model 5a Milling machine and Myford Super 7 lathe. I must say were very impressed with the capabilities of both machines especially considering they're age. I basically spend all day every day machining and I love it.
      I'm sure it will be nice to chat to some of you and of course soak up some of the wealth of knowledge floating around.
      Karl
      Karl Challis
        @karlchallis22968
        Intro
        #404773
        David George 1
          @davidgeorge1
          Hi Karl welcome to the forum. Nice to see younger toolmakers on here as an ex- apprentice toolmaker myself when CNC was never heard of and auto lathes were the latest thing. I have seen many changes like we had to file a shape to a couple of thou for RR turbine blade dies by hand and checked on a shadow graph. Now three years into retirement I hope you have as varied a time with engineering as I have had.
          David
          #404791
          Karl Challis
            @karlchallis22968
            Thanks David, not quite filing to tight tolerances however i have had experience grinding tool steel and using a shadowgraph as measurement, haven't seen one since my early apprenticeship. Glad to still have access to the likes of radial arms as they also seem to be disappearing. I was so lucky to make my start using dial machining and no readout, no 3d clocks, simple edge finders and well placed rolling papers for 10micron shim. It certainly put me in a great position to learn the newer techniques. I can only imagine some of the projects you have taken on in the past. Thanks for the welcome. Karl
            #404813
            Ian Johnson 1
              @ianjohnson1
              Hi Karl I'm in Cheshire so not too far from you, and it's great to see the next generation of engineering talent appreciating the old skills. When I did my apprenticeship NC/CNC were just becoming more common in engineering workshops (in ours anyway!).
              It's a great time to start an engineering company, STEM training in schools is really being promoted, ensuring a pool of workers. Grants and loans are available for start ups especially in the advanced manufacturing in the Liverpool region. There are loads of specialist CNC machining and engineering companies in the area such as Maxton in Frodsham doing very well in motorbike racing suspension. Go for it!
              Ian
              #404817
              Karl Challis
                @karlchallis22968
                Thanks for the positive words Ian.
                And the advice is appreciated. We have always been advised to pick a market/industry and excell in one rather than provide an okay service in multiple industries. I must admit the unpredictability of a general machine shop keeps the work more exciting.
                Do you still machine?
                Karl
                #404823
                Ian Johnson 1
                  @ianjohnson1
                  I still do machining Karl, although it's small hobby stuff now in my garage with small lathe and mill, with a CNC mill all bench top. I've had some career changes but when I was on the tools it was all big heavy chemical plant machining, pump shafts, railway loco wheels, heat ex-changers, pump casings, relief valves, etc, in every conceivable material you can think of. We machined everything really. Probably very much like you want to do.
                  Ian
                  #404849
                  Chris Evans 6
                    @chrisevans6
                    The "jobbing " or general machine shops certainly give you a variety of work. I spent 50 years as a toolmaker in the injection mould and pressure die industry. Now retired with a 14"x40" lathe and Bridgeport mill in the garage for motorcycle projects. I get a lot of challenges on how to make/repair stuff. I did have the good fortune to operate CNC machines in my time but never got on a CNC lathe or mill, my experience was on solid sink EDM and wire cut machines. Enjoy your job.
                    #404866
                    Karl Challis
                      @karlchallis22968
                      I'm currently in the plastic moulding industry myself at the moment, having come from a background in aerospace and pharmaceutical.
                      I just truly dont see the challenge / fun in having software simply generate a program for you. It really seems like automation is the way to go, which is a shame.
                      Again thanks for the welcome guys.
