Hi. I am in the process of trying to build myself a modest workshop. At the moment i use the local Makerspace in Newcastle upon Tyne. As money is really tight, i hope to make as many tools as possible myself. To this end i'm designing a 6" wide linisher based on a 1.5kw capacitor start/run motor of a certain auction site. The rear of the case was slightly dented when i got it, which jammed the fan and so the shaft would not turn. Now i've sorted that out i need to test it under power. It apppears to be an unused surplus Electrodrives Alpak machine.
This is my question: where do you connect the earth from the mains supply? there is a thread on the end of one of the capacitors-what is it's purpose? Is that an earth connection? If so, do i take a connection from it through a hole drilled in the side of the control box and connect to my three core mains wire there, before drilling another hole for the cable to exit to the power source?
This is my first time playing with induction motors, so please be patient with me!
Many thanks.
